justindavid Occasional Visitor
Posted: Mon Nov 12, 2007 10:05 pm Post subject: Widescreen on a PDA |
Can you tell me if i can turn the TOMTOM screen around to display as landscape as i want to mount my PDA in Landscape
Justin |
Posted: Mon Nov 12, 2007 10:16 pm Post subject: |
Have a read of This Post which should explain the issue and solution - Mike |
Darren Frequent Visitor
I've moved your query to a more suitable forum. The answer depends on what version of TomTom you have and on what device it is running? _________________ Darren Griffin |
aj2052 Frequent Visitor
Posted: Tue Nov 13, 2007 3:07 am Post subject: |
You can turn the the screen around in TT5 within the TomTom program, but in TT6 you will need at least win 2003se to enable both Portrait and Landscape within the operating system because the facility was removed from TomTom in this version. |
tcs17_tim Lifetime Member
Joined: 30/12/2002 21:41:31 Posts: 130 Location: United Kingdom
Posted: Sat Nov 17, 2007 5:58 pm Post subject: |
Any of you techies out there know if it's possible to make some sort of bat file to turn the screen then load TomTom.
I keep forgetting to turn it around and the power socket of my pda is at the bottom so I have to mount it very high on the screen to fit it in portrait. |
Posted: Sat Nov 17, 2007 6:40 pm Post subject: |
If your on 2003se, then you should be able to map one of the buttons to rotate the screen, what pda and TTn vers are you on, more help may then be available. |
Posted: Sat Nov 17, 2007 7:36 pm Post subject: |
Mio A701, good idea I will look at using a button. |
