aj_irishman Lifetime Member
Posted: Sat Aug 18, 2007 11:00 am Post subject: Sony NV-U92TW |
Just bought a Sony NV-U92TW and I am trying to install the safety camera feature. All I get is "An error occured. File has not been copied"
Phone Sony - awaiting a call back from a technical specialist.
Also tried to remove languages using the option on the CD and get "There is not enough free storage on the selected drive"!!
Anyone solved these problems? |
Hilbert Occasional Visitor
Posted: Tue Aug 21, 2007 9:38 am Post subject: |
Hi There,
I've just bought the 72T. Over all it's working well and doing a good job, even the TMC is working , however, I'm having similar problems with the speed camera database and get the same error .
One other problem I've had, when I go into route planning and input a relatively log route, say 300 miles or so, the unit crashes halfway through its calculations and flashes up an error about the memory card before rebooting. Has anyone else seen this? Is is a memory problem and would removing the languages improve things do you think?
Hilbert. |
Posted: Tue Aug 21, 2007 2:07 pm Post subject: |
Mega weird.
Sony phoned back again - went through the same steps and it all now works!!
Must have been the vibes from the sony man that did it [or maybe it just needs a few days of operation to sort itself out]. |
Posted: Sun Aug 26, 2007 7:44 pm Post subject: |
Hi aj_irishman,
Glad to hear yours is working now. I'll give it another try too. Did you delete some languages before installing the speed cameras?
Cheers,
Hilbert |
Posted: Mon Aug 27, 2007 10:41 am Post subject: |
no - just re-executed the download and it worked this time. I did notice that a number of .tmp files in the top level of the device [seen via explore in ActiveSync] had been deleted [a house keeping function must have run].
If you can delete unwanted languages then I would - I believe a space issue is somehow involved. My other trouble was that deleting languages didn't work either. |
solpap Occasional Visitor
Posted: Fri Nov 09, 2007 7:05 pm Post subject: What number did you phone? |
Hello there!
I have the unit for about a week, and no matter how many times I tried to install the speed cameras I have failed.
I downloaded the file (it is active on my profile at the Sony website), but no matter what I do it wont install. I run Windows XP and ActiveSync works. I doubleclick the file and then I get a "file copied" notification. Then I disconnect, it is "loading" as if something will happen but the Advanced Warning menu never appears.
I emailed Sony a week ago but no reply which is a joke!
I like the device, but i think I will take it back unless the cameras work.
Could you please tell me the number you phoned as I couldnt find it anywhere?
Many thanks
S |
Posted: Fri Nov 09, 2007 7:50 pm Post subject: Sony Support Contact No |
Cannot remember - I believe I tried the AV number
If you are calling from England, Wales & Scotland, Please dial : 08705 111 999 9am to 5pm, Monday to Friday.(7.9p per minute from a BT landline. Costs may vary for other networks).
If you are calling from Northern Ireland or Eire, Please dial : (00 353) 1 413 1771 9am to 5pm, Monday to Friday. |
Posted: Fri Nov 09, 2007 8:45 pm Post subject: |
May thanks aj_irishman!
I also uninstalled a few languages, but no luck again. However, your mention to memory made me look further and I found that the device has 206mb free and the safety camera file is 485kb.
Could you please tell me in which folder in the device does the file get copied?
I also tried to uninstall a few countries but this is not an option!. Its either Europe A or Europe B alltogether and you cannot select only one country. Very frustrating....... |
Posted: Sat Nov 10, 2007 11:54 am Post subject: Uninstall |
Pass, Couldn't find the safety camera POI files - not obvious, at least to me.
When you run the installation CD you see all the languages that are installed on your machine - I removed all except english [you can always reinstall them from the CD of needed]. |
Posted: Sat Nov 10, 2007 9:31 pm Post subject: Solved! |
Hello,
problems solved!
I will start a new thread, so hopefully people with the same problem will find it easily.
Many thanks for your hellp! |
noel155 Occasional Visitor
Posted: Fri Nov 23, 2007 3:53 pm Post subject: Re: Solved! |
solpap wrote: | Hello,
problems solved!
With a Sony NV-U71T, I try to install the new software version 2.00.07 (cf http://support.sony-europe.com/eve/navigation/downloads/update.asp?l=fr&f=nv_5171).
I get an error when trying to install : "There is not enough free storage capacity on the selected drive"
I test installation from 2 different PCs (XP pro and 2000), and with 2 different versions of ActiveSync (including the last one) without success.
I manually copied the uncompressed files from the HDD to the GPS temp directory to verify there is no space available problem.
Now, I have no idea.
If somebody can help me... |
martinx Occasional Visitor
Posted: Sun Dec 30, 2007 12:59 pm Post subject: |
solpap wrote: | I also tried to uninstall a few countries but this is not an option!. Its either Europe A or Europe B alltogether and you cannot select only one country. Very frustrating....... |
After one nice review, I bought NAV-U 92T and there is no bluetooth and only EuropeA map, not EuropeB.
How can I switch/upgrade map in my device?
What is NVD-U11E Map update and how to use that.
There is no info on sony web site. |
Posted: Wed Jan 02, 2008 10:05 pm Post subject: |
I found it only in this FAQ document. |
