groovyf Occasional Visitor
Posted: Sun Nov 04, 2007 11:13 am Post subject: Planning route now requires GPS signal? |
Bought my GO 720 a couple of months ago, and was quite pleased that routes could be planned without the need for it to have a GPS signal (unlike my old Dell PDA +Nav 5 package)
Now it seems it doesn't work that way anymore which is a real pain. Was this a "fix" applied in an update? |
Oldboy Pocket GPS Moderator
Posted: Sun Nov 04, 2007 11:22 am Post subject: |
You can do Advanced Planning A - B with a GPS Fix, although in V7 it's now called Prepare Route. _________________ Richard
Posted: Sun Nov 04, 2007 11:27 am Post subject: |
Excellent.
Thanks a lot, Oldboy |
Nibo Occasional Visitor
Posted: Sun Nov 04, 2007 11:52 am Post subject: |
Hi all,
I have also bought a GO 720 recently and have a similar issue in that I can't plan a detailed route when I have got a GPS signal - by this I mean being able to set a start point other than the current position, and add more than one waypoint.
"Prepare Route" will let me plan with a GPS fix but will only let me add one waypoint using "Travel Via" , so I need to be able to use "Itinerary planning" mode, but this seems to always takes the current position as the start point.
Hmm, I used to be able to do this no problem with my old Mio 269!
Does anyone know if there's a workaround for this, or if it is possible to disable GPS reception? If disabling GPS is possible I think I can make the GO think that it is starting from an alternative point using Demo mode.
TIA. |
Posted: Sun Nov 04, 2007 3:26 pm Post subject: |
Nibo wrote: | Does anyone know if there's a workaround for this, or if it is possible to disable GPS reception? If disabling GPS is possible I think I can make the GO think that it is starting from an alternative point using Demo mode. | One of the uses of HOME is that you can operate the virtual GO on the Computer.
This will allow you to set a Current Position and to plan routes and Itineraries. The GPS is disabled at this time as the GO is merely a Card Reader. _________________ Richard
Posted: Sun Nov 04, 2007 8:09 pm Post subject: |
Thanks Oldboy, doing it through HOME works fine. Bit of a shame that you can't do it while out on the road but perhaps that's expecting too much . |
46jimbo Regular Visitor
Posted: Sun Nov 04, 2007 9:11 pm Post subject: |
Quote: | Bit of a shame that you can't do it while out on the road but perhaps that's expecting too much |
I read a post on this topic a long time ago where one fellow wrapped the top part of his TomTom in aluminum foil in order to block the GPS signal! |
DennisN Tired Old Man
![Tired Old Man Tired Old Man](modules/Forums/images/ranks/moderator.gif)
![](http://maft.co.uk/avatars/dennis.jpg)
Posted: Sun Nov 04, 2007 10:47 pm Post subject: |
Nibo wrote: | I need to be able to use "Itinerary planning" mode, but this seems to always takes the current position as the start point. | I'm no advance planner of itineraries, but you can save an Itinerary can't you (at the very least, by simply NOT navigating to it there and then)? That will have the first waypoint as the first point to go to from your "current position" and at the time when you actually want to use the itinerary, you WILL want to start from wherever you are at that time, surely (even if it's only 5 feet from the first waypoint)? _________________ Dennis
Two of them are obesiting!! |
Robin2 Lifetime Member
Posted: Mon Nov 05, 2007 1:13 am Post subject: |
If there is no GPS signal, you can plan and run an itinerary. Prepare the itinerary in the usual way and then start it. If there is no GPS signal, you will be asked if you wish to specify a Start position, and when you have done so it will calculate the itinerary in the same way as if you had done it using TomTom Home.
I first saw this feature after updating to v7 - I'm pretty sure it wasn't there with v6
Robin _________________ TomTom One v3 Europe, Navcore 7.903, Western Europe 835.2420
Satmap Active 10
Plus a lot of other PDA GPS kit, seldom used |
Posted: Tue Nov 06, 2007 10:06 pm Post subject: |
DennisN wrote: | That will have the first waypoint as the first point to go to from your "current position" and at the time when you actually want to use the itinerary, you WILL want to start from wherever you are at that time, surely (even if it's only 5 feet from the first waypoint)? |
That's absolutely true, but I want to be able to plan itineraries, for example, in countries other than the UK (when my current position is in the UK) to calculate the mileage and time involved, and I can't do that with a GPS signal present because the GO always insists on navigating to the first waypoint from the current position during planning/calculating.
Posted: Tue Nov 06, 2007 10:08 pm Post subject: |
Robin2 wrote: | If there is no GPS signal, you can plan and run an itinerary. Prepare the itinerary in the usual way and then start it. If there is no GPS signal, you will be asked if you wish to specify a Start position, and when you have done so it will calculate the itinerary in the same way as if you had done it using TomTom Home.
Robin |
No, the problem is that I can't plan an itinerary when there is a GPS signal! |
mrg2003 Regular Visitor
Joined: 12/03/2003 18:19:15 Posts: 136 Location: United Kingdom
Posted: Sat Nov 10, 2007 9:12 am Post subject: Using GPS without signal |
This is about as useful as navigating with a croation map in England |
