Border_Collie Pocket GPS Verifier
Joined: Feb 01, 2006 Posts: 2543 Location: Rainham, Kent. England.
Posted: Wed Oct 17, 2007 11:00 pm Post subject: |
Quote: | Quote: | My readings elsewhere lead me to suspect the the US Mio uses a speedcam database with the .spud extention. |
Quote: | Yes that's the one. I'm sorry but I have no idea of how that format works | . |
Look for the POI folder, if there is a Speedcam folder inside this, open it.
There should be
POIUpdates.upd (leave intact and do not remove).
Speedcam.spdb (speed cam database)
SpeedcamsUpdate.spud
To make sure everything is 'clean', you can safely delete the two files above as they will be regenerated after adding the camera .txt file.
Download the iGO PGPSW safety cam database and copy the .txt file to the POI folder (or Speedcam folder if there is one). This will update the Speedcam.spdb and SpeedcamsUpdate.spud files. |
smash1 Occasional Visitor
Posted: Wed Oct 17, 2007 11:42 pm Post subject: |
M8TJT wrote: | My readings elsewhere lead me to suspect the the US Mio uses a speedcam database with the .spud extention. The format of these files is different to the .mtc files (and a lot smaller as they don't have so much redundant database space per record). |
Yup, got it to work after a few hours.. I needed to update .SPUD file not .MTC for US.
I got the POIEditor 2007, imported from a CSV file (only free place I know for U.S. cameras is www.tomtomforums.com \ POI \ RedLightCameras). Then you save the file a .GPX and then convert that to .SPUD using GPX to SPUD converter tool.
I think I got what I wanted, but let me ask this. Is there someplace here they keep updated U.S. database of cameras (or is it U.K. only)?
Thanks |
webiky Occasional Visitor
Posted: Wed Oct 31, 2007 12:07 pm Post subject: |
Lost_Property:
You are right, this U.S. MIO use standard format of iGO - it is nice, because my Europe MIO C520 ignore everything there (saved here MIOMAP\MioMap\POI\speedcam) and only SpeedCams.mtc is working well (saved here MIOMAP\MioMap\miotc\pois).
I am looking for programmer of Speedcams_builder_215.exe - this program is great, but there are some problems I would like to solve. Does anybody know contact to programmer? Please let me know, if yes!
Thanks. |
M8TJT The Other Tired Old Man
Posted: Wed Oct 31, 2007 2:37 pm Post subject: |
Webiki. I'll give you a clue. Read the first few posts of this thread
Sallyann Lifetime Member
webiky wrote: |
Thanks. |
What do you want to know?
Sal |
Posted: Wed Oct 31, 2007 2:39 pm Post subject: |
Hi Sal.
You got your reply in whilst I was doing a quick edit to add the user's username.
Trev |
Posted: Wed Oct 31, 2007 4:24 pm Post subject: |
M8TJT:
I wrote to Sal. Thanks for clue |
Posted: Wed Oct 31, 2007 6:54 pm Post subject: |
webiky wrote: | M8TJT:
My pleasure |
micanabp Occasional Visitor
Posted: Mon Jan 14, 2008 3:48 pm Post subject: |
Hi Sallyann
First of all , thank you for the great job you have done .
I tried yesterday your speedcam_reader 201 and it was working fine .
But now it doesn't work with the new Speedcams.mtc of my MIO
It was working with the original built in file speedcams.mtc but after synchronisation on Mio site, i received another file , bigger ,still called Speedcams.mtc working well on my C520 but impossible to read with your program ???
i obtain a lot of things like ( for example )
0.00256,-4693.73184,"UNKNOWN: @0",256,1
or
-13086.22848,-36417.76635,"UNKNOWN: @0",0,1
What is you opinion about this ? Have they changed the data format in their file ? but in this case the C520 software must have been changed to ?
I would like to compare the two files to see the speedcams added but i can't
Have you an idea to read the new file ?
Sorry for my bad english but there is a long time since i learnt it
(if you want i can upload the file on http://dl.free.fr/ ) |
Posted: Mon Jan 14, 2008 5:33 pm Post subject: |
That is the first time I have heard of this.
Please upload the file to your server and send me a link in a PM.
It might take me a little while to check it out.
Sal |
Posted: Mon Jan 14, 2008 5:55 pm Post subject: |
Sallyann wrote: | That is the first time I have heard of this.
Sal |
I sent the link by PM
Thanks for your help
Michel |
Posted: Mon Jan 14, 2008 8:58 pm Post subject: |
Oups !!!
You are right, I'm very sorry .. I don't know at all what happens
Some problem when my first copy and paste ?
I transfered the file once more and now it is working nicely with your reader .
A big thank you for your reply and your kindness
Michel |
Posted: Mon Jan 14, 2008 10:12 pm Post subject: |
No problem Michel
Sal |
Posted: Mon Jan 21, 2008 3:43 pm Post subject: |
Hi !
Just a question
I would like to add some speedcams and cancel others but is it working that way . ?
I have tried first without any change of the asc to see what it was doing ..
I have got a file .asc from my original .mtc with the reader.
Then with the builder with the same asc i can create another .mtc but it is different of te first one . same size but when editing in Hex it is différent ( for example No "mitac " at the beginning 6487AE02004D69746163 )
Any mistake once more ?
Thanks for your patience ..
Have a nice day |
Posted: Mon Jan 21, 2008 6:12 pm Post subject: |
There are some changes from the original file, Michel.
That is correct and it makes no difference to the operation.
Sal |
