Pocket GPS World :: View topic - icon display order
icon display order
Svengali_uk
PostPosted: Tue Oct 30, 2007 9:49 am    Post subject: icon display order Reply with quote
I have just had to buy a TTG 700 (after my 300 got nicked), and I find that my "turn on / off sound" icon is buried several pages down the line.
In my 300, this was on the first page that opened up after I tapped the screen - and this is where I want it! (I seem to remember a sound on/off icon appearing superimposed on the running map, which would be even better).
Can anyone please tell me how I can re-site this icon?
TVR
PostPosted: Tue Oct 30, 2007 9:58 am    Post subject: Reply with quote
What Firmware/software version is on your G700?
If 7.12 or later, this does not work with the software development kit (SDK) and can't be amended, as yet.
If prior, is it located at the bottom row, middle position on the second screen? If yes, then just tap the "blue arrow"/car icon on the main map 3 times to mute and same again to activate.
Hope this is of use to you, svengali.
TTFN
TVR
Sygic for android in HD
Cameralert - pending
TomTom consigned to the bin, after 6 years loyal service.
View user's profile Send private message Yahoo Messenger MSN Messenger
Svengali_uk
PostPosted: Tue Oct 30, 2007 10:16 am    Post subject: Reply with quote
My version seems to be 5.419 (Which surprises me, as I thought I had updated via TT Home), but your three-times tap certainly works.
Many thanks.
PostPosted: Tue Oct 30, 2007 12:55 pm    Post subject: Reply with quote
The "3 taps" trick works on the latest software too, as the menus haven't changed.
AFAIK TVR, the sdkmenu will still work on all software (it's used on Mike Alder's "fix" to un-cripple the new ONE third edition), but as the mute icon is in a sub-menu, it might not be moveable anyway.
On v7 you can also add the mute icon to the new "quick menu"
TVR
PostPosted: Tue Oct 30, 2007 2:37 pm    Post subject: Reply with quote
Hi again Andy,
The reason I said use the3 taps trick for th older software is that I don't have first hand knowledge of Go 700. I was sure if the software was the same. At least I know know. Thanks.
If you have a MNU file in the SDK you know that you loose the "help me" feature. Although I do need to look at Mike Alder "fix". does this work around the problem?
What quick menu? Surprised
TVR
PostPosted: Tue Oct 30, 2007 2:59 pm    Post subject: Reply with quote
No, Mike's "fix" puts back the itinerary and user POI functions but loses the "Help me.." and "Mapshare" ones because they are coded in a different way and don't have menu items at all.
"Quick menu" in v7 is actually a rather good idea... You have a transparent icon on the left of the main navigation screen to which you can assign one or more functions that you want to get to very quickly. The whole list you can pick from is:
TomTom Jukebox
Report safety Camera
Mark Location of Map Error
Navigate to Spoken Address
Navigate to Postcode
Add position to Favourites
FM transmitter
Call...
Help me
Switch 2D/3D view
Switch day/night view
Show Weather
If you have just one selected, you get that icon and tapping it does that function immediately. If you have several, you get a green circular arrow icon that takes you to a page with just the ones you've chosen on it.
Svengali_uk
PostPosted: Tue Oct 30, 2007 6:27 pm    Post subject: Reply with quote
I have just looked up the "Mike's Fix" link, and to a tyro it is frightening, is there a step-by-step guide, so that I know I am doing exactly what must be done - for a Go 700?
Also, I have just finished enabling Mullet's sound files (ogg). Will I need to do all these again, also, if I update my firmware (It looks as if I am some way behind), and load the latest POIs, will I again, need to re-enable my ogg files.
Just what order should I take all these steps in?
PostPosted: Tue Oct 30, 2007 7:35 pm    Post subject: Reply with quote
Have a look at Gregory Duncans Menu builder as this provides a nice graphical method to "build" your required menu and creates the text file required for the device, please click Here - Mike
Svengali_uk
PostPosted: Tue Oct 30, 2007 8:10 pm    Post subject: Reply with quote
Hi Mike, the link appears to load, but all I get is a blank page.
PostPosted: Tue Oct 30, 2007 8:20 pm    Post subject: Reply with quote
Give it another try as it appears to be working now, it wasn't when I first checked it following your last post - Mike
TVR
PostPosted: Wed Oct 31, 2007 9:26 am    Post subject: Reply with quote
Andy,
Thanks for the Info., but the only quick menu available to me is the mapshare one. Is this what you are refering to?
I think, more likely, that this is another feature missing from TT1V2's v7 update Rolling Eyes
TVR
23.054 (28 May 25)
