Pocket GPS World :: View topic - Medion gopal pna205 error "please insert the memory ca
masternige
PostPosted: Mon Aug 27, 2007 9:43 pm    Post subject: Medion gopal pna205 error "please insert the memory ca Reply with quote
Hi folks i have got a Medion gopal pna205 and i have formated the flash.Now when i turn it on i get the error message " Please insert the memory card" can anybody please tell me how to fix this i do have 4 cds that came with the device when i bought it but they dont help,im new to this it was my first satnav and i have screwed it up please help. Smile
Please dont ask me why i formated the flash,it was an accident.i have only had it a week.
thanks.
DaveNN
PostPosted: Wed Aug 29, 2007 1:21 pm    Post subject: Re: Medion gopal pna205 error "please insert the memor Reply with quote
thanks.
Have you put the Map Regions Folder back on the FD?
Jaguar XF R Sport AWD
Onboard nav with live stuff, weather, news and stuff.
NextBase Duo DashCam
Running Cameralert via Samsung S7 Edge
PsychoJock
PostPosted: Sun Oct 21, 2007 8:27 pm    Post subject: Reply with quote
Dave,
Having done the same to mine (Medion PNA210T),as you know, would it help hime to do the following.
Use the CDs to create an INSTALL folder on his PC, ActiveSync it to his FD then Hard Reset.
Dave, see PM re: this post
I know I've not had mine long either but I have learnt a lot, the PAINFUL way!!!
Regards
PsychoJock
Confused
DaveNN
PostPosted: Sun Oct 21, 2007 8:40 pm    Post subject: Reply with quote
PsychoJock wrote:
Dave,
Regards
PsychoJock
Confused
I've noticed Very Happy
Now.....have you learnt how to change the voices or add spoken warnings for the speed cams???
Like Noddy, I'm all ears!
That should be the tea time challenge.
RE:- mail on private email address....you need the info still???
PsychoJock
PostPosted: Sun Oct 21, 2007 8:47 pm    Post subject: Reply with quote
Dave,
I have tried recording my own directions, using the same bit-rate etc for the .wav file, but I can't get it to work!! If i get any success, i'll let you know,as for the speedcam warnings - no idea how to do that, will work on it!! Very Happy
PsychoJock
DaveNN
PostPosted: Sun Oct 21, 2007 9:12 pm    Post subject: Reply with quote
PsychoJock wrote:
Dave,
PsychoJock
OK.....I currently use the usual shutter & cash register wavs for the cameras.
Curry houses have a f*rt wav & Little Thief's a diarrhoea wav.
fitch
PostPosted: Tue Oct 23, 2007 7:31 pm    Post subject: Reply with quote
PsychoJock wrote:
Dave,
PsychoJock
Hi you guys,
as you are referring to the pna205 can you tel me if you have installed the POI warner de for cameras?
I have tried quite a few times but the device keeps getting an error after I have input 2 or 3 zip codes.
I have installed it on my memory card as I had memory low errors but I still get memory low or illegal function
any advice?
DaveNN
PostPosted: Tue Oct 23, 2007 7:45 pm    Post subject: Reply with quote
fitch wrote:
PsychoJock wrote:
Dave,
PsychoJock
Hi you guys,
any advice?
Install it on the FD & put your maps on the SD, this should help with the low memory issues.
DNN
fitch
PostPosted: Tue Oct 23, 2007 8:52 pm    Post subject: Reply with quote
thanks for the quick reply.
I have tried various combinations using the sd card but same results.
I am trying your suggestion but is the original poi warner directory and files supposed to be removed?
tia
Phil
ANOTHER1
PostPosted: Sun Mar 15, 2009 9:01 pm    Post subject: Medion Gopal PNA 210 Problem Reply with quote
Medion Gopal PNA 210 - Can anyone that still has this model advise if they have come across this problem and suggest possible solutions. When I start the machine it goes to a Go Pal screen with a spanner and compass icon. When I click on the latter nothing happens. When I click on the spanner it comes up with the message "Please insert the memory card" but when I insert the replacement card on to which I have copied the MapRegions folder (same as the FD) the machine just restarts and I get the same log-on screen. Can anyone advise what may be wrong or what eactly should be on the SD card as this is a replacement card. Thanks.
PostPosted: Sun Mar 15, 2009 9:18 pm    Post subject: Reply with quote
Quite often data stored on the memory card is locked to the specific card supplied with the device, as such it can be copied to another card but when encripted and locked to the card ID it simply won't work in the device - Do you still have the original card that was supplied with the device - Mike
ANOTHER1
PostPosted: Sun Mar 15, 2009 9:29 pm    Post subject: Reply with quote
Hi. Thanks for your reply. Looks like we may be xxxxxx. My brother bough this recently off some auction somewhere - thought he had a bargain but I would have been suspicious that it came with no card (thought that was optional though for this model). Took me ages to figure out that the map was on the device in the "My Flash Disk" but still no luck in getting this to work.
PsychoJock
PostPosted: Tue Mar 17, 2009 7:54 pm    Post subject: Reply with quote
Here's the Gen with regards the Medion 210T.
It was designed as a budget SatNav and as such is a cracking piece of kit. I've had mine for nearly two years now and it has paid for itself numerous times.
The Nav Software sits in the "MyFlashDisk" and I keep my maps on the SD Card. NOte:It ODES NOT come with an SD Card, you have to but your own.
If you are seeing the two grey buttoins on Power up then the "MyFlashDisk" has been formatted and you will need to re-install the software.
I am currently working on a guide for another user on what to put where from what CD. When I have it finished I will post it for all to see.
Have Faith and lots of patience Laughing
Kind Regards
Psychojock
Gary
Medion PNA210T,GoPal Navigator 3(ME),POIWarner 2
Samsung S8000 Jet, Looking for Navigation App?
PsychoJock
PostPosted: Tue Mar 17, 2009 7:55 pm    Post subject: Reply with quote
I really need to watch my typo's!!
Laughing Laughing Laughing
Gary
ANOTHER1
PostPosted: Tue Mar 17, 2009 8:29 pm    Post subject: Reply with quote
Hi "PsychoJock"
Many thanks for your reply. After I posted here on Sunday, I kept on trying to figure out what the issue was. I could see that the maps were on the FD, so knew I wasn't missing anything (other than maps being from 2005/6 I think - anyone know if Medion or Navteq issued map revisions for this device?) other than the maps on a CD (for some reason we had two of the same cd of Medion navigator v1 in the pack). Having tried various things I decided to clear the contents of the FD (other than the Map Regions folder) and copied the install files from the CD for GB to the sd card. Once I restarted the machine the application installed again. Therefore, it appears, in my case anyway, that if there are files in the FD then re-install does not always happen until it is cleared. I hope this helps others and thanks to all for responding to my query!!
