Pocket GPS World :: View topic - TT520 mp3 player
TT520 mp3 player
bazzza
PostPosted: Thu Oct 18, 2007 11:34 pm    Post subject: TT520 mp3 player Reply with quote
I have loaded a lot of mp3 files onto a 1gb SD card and they play ok except that when I look at the contents of the card using explorer it shows a list of titles which is fine, but when I look at the list of songs on the TT520 it is not the same, with many of the songs showing only as "Track 1" or "Track 2" etc. For what it's worth, the mp3 folder on the TomTom itself is empty.
Any ideas?
Bazzza
TTGO520 Version 9.430
Western & Central Europe Maps
Iphone 6
TT Via 135M
GO520 WiFi
PostPosted: Fri Oct 19, 2007 2:52 am    Post subject: Reply with quote
The TOmTom uses the ID3 "tags" contained in the mp3 files NOT the filenames themselves to show song title, album and artiste.
You can use Media Player or iTunes to view and edit the ID3 tags (right click on a song in iTunes, select "get info" and then select the "info" tab)
If you use iTunes to create the files from CD it will add the details automatically.
I've noticed with some songs that any entry in the "comments" field can confuse the TomTom though.
bazzza
PostPosted: Fri Oct 19, 2007 10:40 am    Post subject: Reply with quote
Thanks Andy, I don't have ITunes, I use Media Player. Can you talk me through the way of using that. Do I need to delete the tunes from the SD Card and start again?
Bazzza
Iphone 6
TT Via 135M
GO520 WiFi
bazzza
PostPosted: Sun Oct 21, 2007 9:21 pm    Post subject: Reply with quote
It's sorted now thanks.
Bazzza
Iphone 6
TT Via 135M
GO520 WiFi
PostPosted: Mon Oct 22, 2007 10:05 am    Post subject: Reply with quote
Sorry, missed your post. Glad you sorted it.
bazzza
PostPosted: Mon Oct 22, 2007 6:55 pm    Post subject: Reply with quote
Andy, Just for your info (and anybody else's), In Windows Media Player, the bit that changes the name in the mp3 file is "Advanced Tag Editor".
Bazzza
Iphone 6
TT Via 135M
GO520 WiFi
xda
PostPosted: Tue Oct 23, 2007 1:10 am    Post subject: Reply with quote
If you right click on the Album Icon and select Find Album Info it will download all the information related to that album via the internet. Including Album cover, release date, gene, composer etc.
Graham.
Map: Europe V910.4892
Nokia 925 Windows 8
razor302
PostPosted: Sun Nov 04, 2007 11:13 pm    Post subject: TomTom Go 520 Reply with quote
Hi there,
Hopefully someone can help me out. I have just purchased the 520T and am really pleased with it. I just have one issue. I cannot seem to play my Mp3s from my SD card as it does not offer me the option of the SD Card folder. Am I missing something here? I have an mp3 folder in my main memory where the built in player defaults to.
Hop someone can help me out with the please?
Regards Ray
PostPosted: Mon Nov 05, 2007 3:32 am    Post subject: Reply with quote
Just make a folder on the SD card called "mp3" (lower case, no quotes) with Windows Explorer.
Any mp3s in either the folder on the SD card or in the internal flash memory should show up in one long list in the Jukebox.
bazzza
PostPosted: Tue Nov 06, 2007 11:15 pm    Post subject: Reply with quote
The 520 is playing my mp3 files ok now except for the volume thing. This is TT's response.
Me.
Why do I get a huge increase in volume when I switch to FM radio after listening to the mp3 player on my 520?
Them.
You probably have the output of the 520 set low so the card radio volume needs to be higher.
Me.
This is not the case. I have the volume on the TomTom set to max.
It appears that the output from the TomTom is too low, even when set to max. I have noticed on the TomTom forums that a lot of other people have the same problem.
Them.
Try finding another 'clear' frequency on the raido and tune the FM mount to it . What often happens is that although a frequency appears to be clear there is often 'spill-over' from an adjacent transmitter and this interferes with the signal from the FM effectively attenuating it.
Me.
I tried a couple of different frequencies but the result is the same. Could it possibly be that the FM output that you have set on the 520 is too low?
Them.
If you have the volume on the device itself turned up I regret that its not possible to increase the volume in any other way.
Note that at no time is it considered that the fault may lie with them.
Bazzza
Iphone 6
TT Via 135M
GO520 WiFi
vibeone
PostPosted: Wed Nov 07, 2007 12:28 am    Post subject: Reply with quote
bazzza - its a well known fault/annoyance - yes its too quiet. not your fault, theirs, hopefully will be fixed in a software update.
technik
PostPosted: Wed Nov 07, 2007 12:37 am    Post subject: Reply with quote
It's not a well known fault, and is surely car dependent?
Since recent firmware upgrades the 720 is now too loud on MP3 in my car.
I now have to turn the 720 volume down to avoid distortion on my OEM factory Blaupunkt stereo, which means my satnav directions are a bit low in volume now. It was all fine before the updates.
PostPosted: Wed Nov 07, 2007 1:01 am    Post subject: Reply with quote
The issue is with the sound level (be it mp3 or nav voices etc) from the FM transmitter of the TomTom when compared to a normal radio station, I find I have to lower the volume by a considerable amount when switching from the TT device to any other sound source in the car.
I have to say I have not noticed any difference with any of the recent Navcore releases with respect to FM transmitter output volume, there is a definite 25% difference between TomTom audio levels and those used by Kenwood/ Pioneer which I have in my vehicle when I switch between the FM Tx mode and other audio sources - Mike
PostPosted: Wed Nov 07, 2007 12:03 pm    Post subject: Reply with quote
I agree with Mike's findings...
The problem really comes down to there just being too many variables happening at once. You have:
1. different voices (TTS or real) needing different volumes on the unit,
2. different outputs available,
3. vastly differing levels of mp3 files (try ripping a CD from the 80's and compare it with a recent one), and
4. different levels of FM radio stations to match too (compare R3 to a commercial pop music station)
at least.
I think the best solution (which I've suggested to TomTom, but I'm not holding my breath...) would be for them to produce a "Volumes" page with separate sliders for every source:
voices/
warning sounds/
music/
hands-free phone audio
etc.
Then they could get rid of the "hidden" hand's free volume control and have the main volume control (that you get by tapping screen bottom left) as the INTERNAL SPEAKER volume.
While I was at it, I suggested they made the muting of mp3s when a navigation instruction happens, OPTIONAL on all outputs (especially the FM), like it is for the Bluetooth output.
I think that they could then satisfy everyone's differing needs.
