sheiabah Lifetime Member
Posted: Sat Oct 13, 2007 5:44 pm Post subject: Displaying POI's on nuvi 310 |
When I first got the unit POI icons were dispalyed on the maps, after some updates the POIs stopped diplaying the only ones I can see are the destination points I have added am i missing a setting somewere, POI loader is upto date and I am using Ashes wonderful camera manager. Any ideas
Many thanks |
Tazz070299 Lifetime Member
Posted: Sat Oct 13, 2007 6:07 pm Post subject: |
Sorry I can't help you with this issue, but I had to reply because I was puzzled how I could reply to a question posted on 14 October, when it's only 13 October
Tazz
Edited to confirm that I actually posted this reply at 18.20 on 13 October, not 14 Oct as suggested by the site. |
Posted: Sat Oct 13, 2007 6:28 pm Post subject: |
Tazz go to your profile and select GMT for your time zone, you will find you have not in fact invented time travel - Mike |
swing Pocket GPS Verifier
Posted: Sat Oct 13, 2007 7:21 pm Post subject: |
If you mean general POI items appearing on the main map screen, then I think you have to be zoomed pretty much all the way in, and only using the 2D map to see POIs. Garmin don't, as a matter of course, display all the POIs you store in the unit - this is good - TomTom have to limit the number of categories to not risk memory problems - by not displaying any, Garmin don't suffer from the memory problems, and hence allow you to have a much large number of Custom POIs on the device in the first place.
If you mean speed cameras that would give you an alert and stay on the screen, and now aren't - I would suspect you'll need to reconfigure Ash's utility to turn back on that facility (however, I don't use Ash's utility to be able to give you any more advice on what to do). _________________ Please don't be offended if I do not reply to a PM - please ask questions via the forums. |
Posted: Sat Oct 13, 2007 8:13 pm Post subject: |
Many thanks, it is the general POI's that I am missing will try the zoom in as I have only loaded a few cats
Thanks Again |
