geddit Occasional Visitor
Posted: Fri Oct 05, 2007 7:00 pm Post subject: Tomtom One SDcard Format |
Having read all the posts regarding SDcard upgrading, I took the plunge and bought a Kingston 2Gb (x30 speed). I formatted it in FAT and copied the files from the Tomtom card over using a card reader. I was disappointed that my Tomtom ran much slower. So I bought a Sandisk Extreme 2Gb (x133 speed) and did the same again. You may be interested in the result...
To calculate a route from the south to the north of england took:
17 secs on original card,
31 secs on Kingston (x33)
24 secs on Sandisk (x133)
BUT
17 secs on Sandisk FORMATTED AS FAT32!
So I know which I will use.
Regards |
Andy_P Pocket GPS Moderator
Posted: Fri Oct 05, 2007 7:55 pm Post subject: |
Very interesting!
Thanks for posting your results.
Anyone know what the card is likely to be formatted to when you buy it?
There's usually no need to format it again before you use it in the TomTom, but if a DIFFERENT format makes it better or worse, it might be worth it. |
biggles150 Lifetime Member
![](modules/Forums/images/avatars/1137662512473a1e073c53c.jpg)
Joined: Jan 09, 2006 Posts: 101 Location: Eltham, London
Posted: Fri Oct 05, 2007 8:20 pm Post subject: |
Andy_P2002 wrote: | Very interesting!
I'm not in a position to do so at the mo', but if you use a card reader, select properties from right click it should give you the format (I think!!) _________________ Go Classic
Application 7.163 (8493/71205)
OS:2328
GB Map v710.1571
Sandisk ultra II 512MB |
Oldboy Pocket GPS Moderator
Posted: Fri Oct 05, 2007 10:01 pm Post subject: |
biggles150 wrote: | I'm not in a position to do so at the mo', but if you use a card reader, select properties from right click it should give you the format (I think!!) | Indeed it does.
Most new cards come pre-formated with FAT32. _________________ Richard
Posted: Fri Oct 05, 2007 10:27 pm Post subject: |
Richard.....it may be an idea to put this info in the FAQ sticky, I'm sure i've seen questions of this ilk on the various forums. _________________ Go Classic
OS:2328
GB Map v710.1571
