Pocket GPS World :: View topic - How many sats?
How many sats?
Petekk
PostPosted: Thu Apr 01, 2004 10:53 am    Post subject: How many sats? Reply with quote
How many sats is it normal to track? (i.e say between 5-7 or something like that?
What is the most sats people have seen?
What is the min for GPS to work on 2D or 3D
Robin2
PostPosted: Thu Apr 01, 2004 12:28 pm    Post subject: Reply with quote
5-7 would be typical, less if you are in a valley, under trees or in a city with tall buildings. I once saw 11 when I was driving across very flat country in Northamptonshire
Robin
Privateer
PostPosted: Thu Apr 01, 2004 1:41 pm    Post subject: Reply with quote
Hi Pete,
As I understand it, the minimum number of satellites to have a lock on for the GPS to work well is 4. If you’re using something like TTNav then the occasional drop to 3 or even 2 satellites for a few seconds won’t compromise navigation. However you should try to position your GPS in your car where it’ll track the most satellites, so you may have to experiment.
3D is a bit of red herring for car SatNav, as you don’t need to know height you are above (or below) sea level as you should always be on the road. 8O If you can get the altitude reading then I believe it can be many metres out from the actual figure. If you desperately need to know the altitude then you’ll have to cross-reference your position against an Ordnance Survey Landranger map or similar. If you must absolutely have an accurate display of your altitude, i.e. if you fly a Micro light or similar, then your best bet is to get an approved GPS unit for flying. Thumbs Up
I’ve occasionally seen 10 satellites, and once I saw 11, but I’ve not yet seen the elusive 12. I agree with Robin that you’ll often see between 5 and 7 satellites on average. Smile
Robert.
Garmin Camper 770 LMT-D
Tim Buxton
PostPosted: Thu Apr 01, 2004 2:05 pm    Post subject: Re: How many sats? Reply with quote
As with the other responses, 5 to 7 sats is my norm.
I've seen the full twelve a couple of times. Got a screenshot somewhere, but can't place it at the moment.
Three sats are required for 2D and four for 3D.
Tim
