Pocket GPS World :: View topic - tomtom one sd help
tomtom one sd help
sharky007
PostPosted: Sat Sep 22, 2007 11:27 am    Post subject: tomtom one sd help Reply with quote
hi i have a tomtom one
i have just purchased a 4.0gb sd card i have transferred everything i backed up off the internal memory and added usa & canada map and also australia but they are not coming up on the tomtom
any ideas why
do i have to do something else
i made shore i ticked show hidden files so cannot understand why
any help much appreciated
gardenshed
PostPosted: Sat Sep 22, 2007 1:14 pm    Post subject: Reply with quote
what tt one is it? v1, v2, v3, this will help people help you Wink
sharky007
PostPosted: Sat Sep 22, 2007 6:45 pm    Post subject: Reply with quote
tomtom one v2
PostPosted: Sat Sep 22, 2007 6:58 pm    Post subject: Reply with quote
Does the unit boot up correctly with the SD card inserted or do you get an error screen - if it does boot which maps are listed in Change preferences/ Manage Maps/ Switch Map - Mike
sharky007
PostPosted: Sat Sep 22, 2007 7:40 pm    Post subject: Reply with quote
it either comes up with usa @ canada with australia or the other way round western europe and canary islands
it will not come up with all of them
is there a way it will?
cheers
PostPosted: Sat Sep 22, 2007 7:46 pm    Post subject: Reply with quote
If all the maps are on the card and they are of the correct version to work with your software then the device should list them all. You do have all the maps on the Memory Card don't you? - and have you tried the reset button under the unit? - Mike
sharky007
PostPosted: Sat Sep 22, 2007 7:55 pm    Post subject: Reply with quote
hi i transferred everything off internal memory on to my 4gb sd card which i then added australia and usa they are v6.75 which my other maps are
thats what i cannot understand
cheers
PostPosted: Sat Sep 22, 2007 8:00 pm    Post subject: Reply with quote
Have you been able to activate the maps using www.ttcode.com - I find it strange the device lists the maps in the way you describe, certain maps one time, the remaining other maps the next? - Mike
sharky007
PostPosted: Sat Sep 22, 2007 8:03 pm    Post subject: Reply with quote
do i need to add all the stuff off internal memory i can i just add some sort of tomtom software with the maps
PostPosted: Sat Sep 22, 2007 8:07 pm    Post subject: Reply with quote
Your first post stated you had indeed transferred everything from the internal memory to the card, my previous post asked about www.ttcode.com - do you want to take some time to post exactly what you have, where you got it from and what you have present on the memory card - Mike
sharky007
PostPosted: Sat Sep 22, 2007 8:12 pm    Post subject: Reply with quote
i have transferred everything off internal memory because there is only about 10mb left to my 4gb sd card i then added australia and usa off of cd to the sd card
thats what i have done you can activate the maps on the tomtom if it would come up with the maps on the switch map action but its not showing them up
so is that right i copied everything even hidden folders then added 2 new maps
sharky007
PostPosted: Sat Sep 22, 2007 8:19 pm    Post subject: Reply with quote
this is what i have exactly on the memory card
canary islands
australia
usa &canada
western europe
gl
home images
itn
licences
raster
statdata
tomtom_cfg
voices
zip
autorun.inf
connect2internet.db
connect2internet.so
connect2internet.ver
currentmap.dat
data.chk
installtomtomhome.exe
libaec.so
settings.dat
system
tomtom.icn
ttgo.bif
ttsystem
westerneurope.mds
thats the exact order of sd card
is this right
PostPosted: Sat Sep 22, 2007 8:28 pm    Post subject: Reply with quote
When you select Switch maps and it lists the additional maps can you select one and then try activating it via the link I posted earlier - Mike
sharky007
PostPosted: Sat Sep 22, 2007 8:36 pm    Post subject: Reply with quote
if i select switch maps it comes up with 2 maps i click on map it comes up its needs activating which you then type in code on tomtom
PostPosted: Sat Sep 22, 2007 8:42 pm    Post subject: Reply with quote
After typing in the codes to the site and the returned code to the device, can you see and use the map? if so try switching to another map and then back again does it require activation a second time or not? - Mike
