Pocket GPS World :: View topic - Alert Information in POI's
Wistow
PostPosted: Fri Aug 31, 2007 12:21 am    Post subject: Alert Information in POI's Reply with quote
Garmin Nuvi610, all updated using the webupdater version numbers unknown
I have created my own POI's for the shops I look after
using the structure of -4.17597,55.760874,"EAST KILBRIDE 01355 236342" in a csv file.
The POI loader wors fine and the POI's are visable in custom POI's however when selecting a POI the screen displays
"Alert Information:"
"Distance: 1319ft"
"Speed: 1mph"
This has not happened with any other csv POI files I have loaded, how can I remove the Alert Information details
Is it possible to edit the Favourites on the PC
Thanks Graham
PaulB2005
PostPosted: Fri Aug 31, 2007 7:10 am    Post subject: Reply with quote
Hi and welcome.
You can edit, backup ands restore Favourites with EasyGps www.easygps.com
Did you load the POIs using Manual or Express method?
Wistow
PostPosted: Fri Aug 31, 2007 6:29 pm    Post subject: Reply with quote
Thanks I will try EasyGps
The POI's were loaded with the Express method. I loaded them in exactly the same way as the other POI's.
I tried copying them to a new cav file but no difference
Graham
PhilHornby
PostPosted: Tue Sep 04, 2007 3:19 pm    Post subject: Re: Alert Information in POI's Reply with quote
"Distance: 1319ft"
"Speed: 1mph"
You must have created a file whose name contains one of Garmin's reserved words, or more likely, you've got a number "1" in the name.
POI Loader applies some "Eye of Toad, Leg of Newt" logic and decides that you want all POI's to have a 1 mph Speed Alert :-)
Wistow
PostPosted: Tue Sep 04, 2007 4:54 pm    Post subject: Reply with quote
Thanks Phil, yes the file was called region 1
Graham
22.055 (29 May 24)
