Pocket GPS World :: View topic - Changing battery in tomtom go 300
fcat
PostPosted: Fri Aug 31, 2007 4:14 pm    Post subject: Changing battery in tomtom go 300 Reply with quote
Are there any websites with pictures text on how to replace the battery on the go 300 ?
have bought the battery and would appreciate any hel/pointers and info
cheers
JockTamsonsBairn
PostPosted: Sun Sep 02, 2007 4:05 pm    Post subject: Re: Changing battery in tomtom go 300 Reply with quote
cheers
Did you not get instructions from the battery supplier?
Jock
fcat
PostPosted: Sun Sep 02, 2007 4:06 pm    Post subject: Reply with quote
nope, but figured it out myself and did the job in 5 minutes,
cheers
JockTamsonsBairn
PostPosted: Sun Sep 02, 2007 4:17 pm    Post subject: Reply with quote
Thumbs Up
Jock
PaulB2005
Would you like to share the information?
fcat
PostPosted: Sun Sep 02, 2007 4:20 pm    Post subject: Reply with quote
1. Remove front bezel
2. unscrew 4 small screws (1 hole has anti tamper tape over)
3. remove "dome" rear of unit.
4. Remove 2 screws holding speaker in
5. Carefully remove all metal tape covering electronics
6. Remove 4 small screws securing PCB to unit
7. Remove 2 screws holding black plastic battery clip
8. Unplug small battery connector from PCB board.
9. remove battery and insert new one
Then do all of the above in reverse!
Unit fired straight up when all put back together
you will need the proper torx head screwdrivers, these came with the new battery i bought for a tenner on ebay.
p.s. torx drive T8 size for outside casing and speaker screws, T6 size for inside screws.
p.p.s. This page might be of help, although found it after doing the job myself
http://www.opentom.org/Hardware_Battery
Robin2
PostPosted: Mon Sep 03, 2007 5:35 pm    Post subject: Reply with quote
Moderators - It might be worth transferring this thread to the All in One forum, so that other users of the Go 300 might see it
Robin
Tis done - Oldboy
Satmap Active 10
buglawton
PostPosted: Sat Nov 03, 2007 3:34 pm    Post subject: Reply with quote
I followed the dis-assembly instructions above, replaced the battery then noticed a small spring had dropped out. Any idea where it goes on re-assembly?
22.055 (29 May 24)
