Pocket GPS World :: View topic - garmin i3 streetpilot
smudger1946
PostPosted: Tue Aug 28, 2007 6:37 pm    Post subject: garmin i3 streetpilot Reply with quote
Hi All, im sure someone out there can help.
My Garmin i3 Streetpilot Version4, has been a great bit of kit which i bought 2 years ago.
Suddenley it wont navigate in real time, all other functions are running perfectly, it is searching for satellites all the time.
As far as i can tell nothing has or has been changed, it will even simulate route.
But wont run.
Help, off on hols in 2 weeks.
Smudger
PostPosted: Tue Aug 28, 2007 6:53 pm    Post subject: Reply with quote
Have you tried resetting the device? - you will have to re-enter certain settings such as Home and POI Warnings etc but it is worth a try.
Hold down the two buttons and the scroll wheel for a few seconds, when it asks about resetting or wiping out settings answer Yes, then see if the device will work correctly - Mike
bald_eagle
PostPosted: Tue Aug 28, 2007 8:06 pm    Post subject: Reply with quote
Have you changed cars and now got a heat reflective windscreen ?
smudger1946
PostPosted: Tue Aug 28, 2007 9:40 pm    Post subject: garmin Reply with quote
no same car, nothing chenged.
JohnWB
PostPosted: Wed Aug 29, 2007 8:18 am    Post subject: Reply with quote
I have an i3 which suddenly stopped working on batteries. After trying all sorts of things including seeing what the price for an out of warrenty reapir would be from garmin (£72) I decided to reinstall the firmware (2.7) it is now back to normal so it may be worth the try as it only takes 5 minutes. There is the slight possablity of killing the unit but it doesn't work now so give it a try.
smudger1946
PostPosted: Wed Aug 29, 2007 9:40 am    Post subject: garmin i3 Reply with quote
Done as advised, re-set unit, unit is now stuck on sweden/ finland map and still cant find satellites, any ideas.
Smudger
PaulB2005
PostPosted: Wed Aug 29, 2007 9:42 am    Post subject: Reply with quote
Have you taken it outside to an area with a good view of the sky and waiting 20 or minutes? Initial lock can take a while.
smudger1946
PostPosted: Wed Aug 29, 2007 1:37 pm    Post subject: garmin i3 Reply with quote
Hi All,
I have got gps out of sweden/finland and it can find sats now, i cant take it out yet as i broke my wrist so cant drive but will try it tomorrow with a bit of luck.
Fingers crossed
Will keep you informed.
Mike i apologise.
Smudge
smudger1946
PostPosted: Mon Sep 03, 2007 12:02 pm    Post subject: i3 Garmin Reply with quote
Hi all, Have taken gps for a spin, she works ok but is still very slow aquiring sat's.
Is this a generael problem at the moment or is there something else i should be doing?
PaulB2005
PostPosted: Mon Sep 03, 2007 12:06 pm    Post subject: Reply with quote
How long does it take?
Do you keep batteries in it when not in use?
Did you try my advise above?
smudger1946
PostPosted: Mon Sep 03, 2007 12:35 pm    Post subject: i3 Reply with quote
It sometimes takes minutes, one day in a return trip of 8 miles she never did find sats, as a rule 5-10 mins.
I did as you advised and it did lock on as you said it did take 15-20 mins.
Keep batteries in most of the time too.
PaulB2005
PostPosted: Mon Sep 03, 2007 12:38 pm    Post subject: Reply with quote
5 - 10 minutes is a long time if you keep batteries in it all the time. Even after a hard reset mine only takes 3 or 4 minutes.
Normally mine takes less than a minute to get a lock.
Sounds like it's developed a fault. Try speaking to Garmin.
smudger1946
PostPosted: Mon Sep 03, 2007 12:57 pm    Post subject: i3 Reply with quote
mine used to be very quick too.
Thanks for your time mate.
Will have to have a word with Garmin.
ANYONE KNOW GARMINS tELEPHONE NUMBER?
Smudger
smudger1946
PostPosted: Wed Sep 05, 2007 6:39 pm    Post subject: i3 Reply with quote
Success, sat nav has been on it's hols to Devon and worked perfectly, WHOPEe.
Thanks to all, for your valuable help.
Happy Smudger Razz
22.062 (12 Jun 24)
