Pocket GPS World :: View topic - MyGuide 3100 - adding own POI
SirJuicer
PostPosted: Sun Aug 12, 2007 2:34 pm    Post subject: MyGuide 3100 - adding own POI Reply with quote
I have searched for this topic already, but couldn't find, so apologies if it's already been discussed.
I've got a MyGuide 3100, added the speed camera database no problem.
I've been emailed two files which contain the location of sites across the country for my job, and they're in the .ov2 format (which I believe to be the TomTom standard POI file).
Are these files compatible with my unit, and if not, how do I go about making them compatible?
If someone could inform me where abouts to put these (or the converted if needs be) files in the MyGuide unit, that would be really helpful too as the only POI folder I can find contains on the Speed Camera locations folder.
Thanks guys,
- Craig.
plasticam
PostPosted: Sun Aug 12, 2007 6:51 pm    Post subject: Reply with quote
You need to use the software from the following location:
http://inetcom.hu/mick/igo/
This works fine with the myguide software (which is basically rebadged IGO) and converts the .ov2 files.
bbdez
PostPosted: Fri Aug 17, 2007 7:24 pm    Post subject: Reply with quote
wot do you export the file as , coz there is 4 things... is it csv poi file, is there a guide to use that tool anywhere?
after using that where do they go in the myguide 3100, is it the same as cams ?
markrider
PostPosted: Tue Aug 21, 2007 8:16 pm    Post subject: Reply with quote
hi i was going to ask the same.
got the soft ware but not sure wa to convert it too or where to put it
thanks very much
mark
peasemore
PostPosted: Tue Aug 21, 2007 11:13 pm    Post subject: Where to put poi Reply with quote
That would seem logical place
ie
\Flash Disk\MyGuide\poi
which is where speedcams go.
Gel
Lifetime Member Thames Valley, Berkshire, UK
Mazda CX-5 built in SatNav- not sure if TT or not. Garmin NUVI in reserve.
plasticam
PostPosted: Wed Aug 22, 2007 6:19 am    Post subject: Reply with quote
Basically copy the iGO.db (this is the database for the POi's) file from the myguide folder on the flashdisk.
Put this somewhere on your PC and make a backup of it.
Open it with the software and update it with your own choice of POi's.
Copy it back to your flashdisk.
Job done
ledshed
PostPosted: Wed Aug 22, 2007 1:28 pm    Post subject: Reply with quote
Igo won`t import the BMP icons for POI you have to use a choice of provided Igo icons
Igo POI Explorer, discovered it thanks to this forum:
Handles converting .ov2 to .txt(?) poi files and loads them into the Myguide 3100, they appear under My POI.Works a treat.
POI editor has Igo`s native format as .upd(?)
Adam
GSX550ES
PostPosted: Wed Dec 26, 2007 10:04 pm    Post subject: Reply with quote
Adam
Can't get this to work, is there an idiot's guide somewhere?
I copied igo.db which when I looked at it via the software was empty. I imported 2300 low bridges (for HGV use) copied them to the .db file & wrote them back. They now appear in the igo.db file if I copy it back again after closing the program. But when using the Myguide I can't see them
Alan...
bakerman
PostPosted: Mon Jan 07, 2008 4:15 pm    Post subject: Reply with quote
finally got IGO Explorer to work ( It needed Active Sync installed on the pc) Ive converted my poi's and imported into the database, been into IGO and under POI's my new catagories are there. Cant see them on the map tho.
What do I need to do to make them appear on the map?
