Pocket GPS World :: View topic - camera alerts
camera alerts
mickeyboy1
PostPosted: Fri Aug 17, 2007 4:04 pm    Post subject: camera alerts Reply with quote
Hi all,
I copied all the files from my tomtom go 510 to the card on my wifes tomtom one, everything seems ok except i cannot get the camera alerts to work.
can anybody help me
many thanks mickeyboy1
radavis
PostPosted: Fri Aug 17, 2007 5:29 pm    Post subject: Reply with quote
Are the camera files in the map directory?
Raymond
PostPosted: Fri Aug 17, 2007 5:38 pm    Post subject: Reply with quote
Change Preferences/ Manage POI/ Warn When Near POI and the camera POI files should be listed, if not there is a problem with the files you have put on the device, or where you have put them.
Assuming they show up (scroll down the list to find them, or type PO on the keyboard to bring them to the top of the list) you will need to set up the warning parameters for each camera category you have installed to the One - Mike
mickeyboy1
PostPosted: Fri Aug 17, 2007 10:21 pm    Post subject: Reply with quote
all the camera files are in the map directory
mickeyboy1
PostPosted: Sat Aug 18, 2007 4:26 pm    Post subject: Reply with quote
hi mike, tried what you said but could not see the cams on poi's.
i have sent you a e-mail with a snapshot of the map folder ( hope you don't mind ). maybe you can see where i am going wrong
many thanks
PostPosted: Sat Aug 18, 2007 5:13 pm    Post subject: Reply with quote
many thanks
It'll serve you right if he's gone out to the zoo!! No real harm done and this is NOT a telling off BUT ... Best post the listing here for all to see and dig into - could well get a faster reply. Most of all, somebody else has had, or will have the same problem and if they see it solved here, they'll reap the benefit of your posts. That's why we encourage public posting - you wouldn't believe the stuff I've picked up by reading other people's posts.
FazerUK
Do you have only one map folder? if you have more then one map folder make sure the camera database is in both
TomTom Go 700,
with External Antenna, External Mike
App v7.160, OS:2324, GPS v1.21, Boot 5.4201
Western_Europe-Map v650.1127
PostPosted: Sat Aug 18, 2007 5:19 pm    Post subject: Reply with quote
Problem is the poor chap doesn't know how to post a picture up on the site, I am still awaiting an e-mail with a picture then I will link it to this thread so everyone can have a read/ look and work out what the issue is - I seem to remember helping out a few others with the issue of posting pictures, so he isn't the only one who finds this troublesome - it easy to do when you know how but it can cause severe nashing of the teeth when you don't.
And while Blackpool does have a Zoo I have not gone there for quite a while - Mike
mickeyboy1
PostPosted: Sat Aug 18, 2007 5:52 pm    Post subject: Reply with quote
my sincerest apologies to all for being a thickie, i will get the hang of this eventually ( I hope )
Edit once to add picture as per the request - Mike Alder
PostPosted: Sat Aug 18, 2007 6:55 pm    Post subject: Reply with quote
Have a look at #7 on the FAQ Page it will explain exactly what is wrong, in short you cannot configure camera warnings when using the TomTom supplied camera database, use the one from this site instead as it is more accurate and considerably cheaper you can also use full spoken alerts and configure the warnings with the Pocket GPS World offering - Mike
PostPosted: Sat Aug 18, 2007 7:08 pm    Post subject: Reply with quote
INCLUDING ME! You will perhaps recall I took some getting through to? Embarassed But you're right, easy when you know how.
mickeyboy1
PostPosted: Sun Aug 19, 2007 12:46 pm    Post subject: Reply with quote
thanks mike, it makes sense now, i will download the database as you sugest.
mickeyboy1
PostPosted: Sun Aug 19, 2007 1:11 pm    Post subject: Reply with quote
hello again, i have downloaded the camera database and following instructions on screen, the thing is do i have to delete the tomtom cameras from my card prior to loading the new ones or leave them there,
thanks again
PostPosted: Sun Aug 19, 2007 1:14 pm    Post subject: Reply with quote
Have another read of the FAQ page (the link to it is in my previous post) this time you want to read #13 which details how to remove the TomTom cameras.
It is possible to have them both on the device but the warnings can get messed up with duplicate entries from each database trying to offer warnings, the easy option is to make sure you have a back up of the device then remove the TomTom cameras from the device - Mike
mickeyboy1
PostPosted: Mon Aug 20, 2007 2:00 pm    Post subject: Reply with quote
thanks for the info, everything is working perfectly now
cheers
22.054 (22 May 24)
