wigfield Regular Visitor
Posted: Thu Aug 16, 2007 3:15 pm Post subject: need a better sd card for my go300 |
as some of you might know ive had problems with my go300 and it could be down to the sd card
also sometimes the voice directions are a bit slow so i thought if i get a better sd card it might solve the problem??
so what sd card should i get for the go300 i dont want a cheap and nasty one could someone point me in the right direction
also when i get it i dont have to format it or anything like that
i know that kingston are good but i have no idea what card to get well i know to get 1gb but which one i dont know
cheers |
Oldboy Pocket GPS Moderator
Posted: Thu Aug 16, 2007 6:50 pm Post subject: |
Any card that is at least x50 speed. I used a ByteStor x80 successfully.
It doesn't need to be Ultra Fast, and every card I've ever bought is pre-formatted. _________________ Richard
Border_Collie Pocket GPS Verifier
Joined: Feb 01, 2006 Posts: 2543 Location: Rainham, Kent. England.
Posted: Thu Aug 16, 2007 7:26 pm Post subject: |
Quote: | so then this would be ok Kingston 1GB 50X ELITE PRO SD Card | You may as well go for the Kingston Ultimate, it's faster and not much more expensive. I use the 2GB Ultimate for my Pocket PC and 1GB Ultimate for photography. Never any problems. |
Posted: Thu Aug 16, 2007 7:34 pm Post subject: |
unless im not look right i can only see Kingston Ultimate 2gb not 1gb? |
Posted: Thu Aug 16, 2007 7:45 pm Post subject: |
Quote: | i can only see Kingston Ultimate 2gb not 1gb |
You're right, I just Googled and can't find a 1GB Ultimate. Maybe they've stopped production in favour of the 2GB. |
Posted: Thu Aug 16, 2007 7:49 pm Post subject: |
i thought i was being dumb
so should i stick to the Kingston 1GB 50X ELITE PRO |
vroomfondel Regular Visitor
Posted: Thu Aug 16, 2007 8:32 pm Post subject: |
wigfield wrote: | ...so should i stick to the Kingston 1GB 50X ELITE PRO |
Thats the minimum recommended speed.
Anyway aren't Kingston just rebadged oem rejects?
So it may not even be the speed it supposed to be.
Theres a long thread here about what works and doesn't
http://www.yournav.com/forum/index.php?showtopic=588 |
Posted: Thu Aug 16, 2007 8:48 pm Post subject: |
now im lost not sure what make/speed to get for my go300 |
Posted: Thu Aug 16, 2007 8:54 pm Post subject: |
Quote: | so should i stick to the Kingston 1GB 50X ELITE PRO |
If you look HERE and check the compatibilty list you'll see it's fine for the Go 300. |
Posted: Thu Aug 16, 2007 9:39 pm Post subject: |
so would that card be faster than the oem card thats in the tomtom
i cant find any info about their cards
i need it to be faster than it is now |
Posted: Fri Aug 17, 2007 12:45 pm Post subject: |
wigfield wrote: | so would that card be faster than the oem card thats in the tomtom.... |
No. You can test the read speed of your orig TT card on your PC.
Above a certain speed the TT will not run any faster as there will be other limitations, but why buy a card that just meets the minimum spec when they are so cheap now?
My mate got a 2GB "hi-speed" SD from Aldi for <£10 and it works fine in his 510 |
Posted: Fri Aug 17, 2007 12:54 pm Post subject: |
ive got my go300 connected to my pc but it doesn't say the read speed?
im looking at the kingston 1gb sd cards and they all say 50x ive not seen any higher ones |
arfurdent Regular Visitor
Posted: Fri Aug 17, 2007 1:04 pm Post subject: |
I tried a Kingston ultimate SD card for my Go300 when the version 6 software came out.
It worked for the version 5 software but was not fast enough for version 6 and just hung on boot up.
Had to get a ByteStor card |
twincarbs Occasional Visitor
Posted: Fri Aug 17, 2007 1:13 pm Post subject: |
i recently bought one of these 133x corsair ones:
http://www.ebuyer.com/UK/product/111441
its worked faultlessly so far. ok, only 512k but plenty for what i need. you may be able to get a larger size.
cheers. _________________ TOMTOM GO 300 |
