dan12345 Occasional Visitor
Posted: Wed Aug 15, 2007 12:54 pm Post subject: Nuvi 350 help needed! |
Hi guys,
While deleting some mp3 files from my nuvi 350 recently, I accidently deleted some contents of the Garmin folder. Luckily I had made a copy of the nuvi drive when I purchased it last year.
However, now that I have transfered the copy back to the nuvi, It doesn't work as it did! Now, when I select any option from the 'where to?' menu, it just gives a message saying 'no map data available'. Even though the map can be seen in 'view map' mode, only motorways and main roads are visible, all the city streets and smaller roads have gone. The 'map info' button in the system menu is now grayed out. (it used to work and showed that map version was city navigator europe NT v8)
I have tried deleting everything on the Nuvi and putting the whole copy back again, and have updated the software to version 4.60 with Garmin webupdater, but still the same problem.
Any ideas anyone?
Thank you. |
PhilHornby Frequent Visitor
Joined: Dec 07, 2006 Posts: 563 Location: North Devon
Posted: Thu Aug 16, 2007 1:40 am Post subject: Re: Nuvi 350 help needed! |
For some reason, you're only seeing the Basemap - not the detailed City Navigator map.
Is GMAPPROM.IMG present? (175MB ish)
If that is in order, do you have a GMAPPROM.UNL containing the 25 digit map unlock code? (I'm not so sure how/when the Nuvi range interacts with this file - I know the Streetpilot C510 only makes sporadic reference to it, usually after major system resets) |
swing Pocket GPS Verifier
Posted: Thu Aug 16, 2007 6:49 am Post subject: Re: Nuvi 350 help needed! |
dan12345 wrote: | Luckily I had made a copy of the nuvi drive when I purchased it last year. | Have you done anything else since the backup was taken - eg upgraded the maps to v9? As PhilHornby says, it sounds like you have lost your map files (although I would expect the map file to be more like 1.3Gb on a 350). Finally, do you know exactly which files you put back (before replacing the whole directory), and, more importantly, can you provide us with a list of all the files in the \Garmin directory now, with filesize...? _________________ Please don't be offended if I do not reply to a PM - please ask questions via the forums. |
Posted: Thu Aug 16, 2007 7:00 am Post subject: |
Hi Phil,
Thanks for your helpful reply.
There is a file named GMAPPROM but no extension. just 'paint shop pro 9 image' and is 1,137.824 KB. Would this be the one you refer to?
There is also a gmapprom.sum file in the Garmin folder, plus a couple of .BIN files, fs-image.ver, Garmin Device XML document, Nuvi-drive icon and GUPDATE.GCD, plus some other folders.
There is no GMAPPROM.UNL file. |
Posted: Thu Aug 16, 2007 7:06 am Post subject: |
The lack of extension could be caused by Windows associated the file with PSP9, although it does appear the file is about the right size.
If you haven't upgraded to v9, there will not be a .unl file on a Nuvi.
Do you also have a gmapbmap.img file? _________________ Please don't be offended if I do not reply to a PM - please ask questions via the forums. |
adrian_anastas Regular Visitor
Posted: Thu Aug 16, 2007 7:27 am Post subject: Windows File Settings |
Hiya,
It could be that you're windows file settings is not showing hidden files. For completeness these are the files in the Garmin Directory of my 350:
006B047800.bin
006B048201.bin
Activation.dat
fs_image.ver
GarminDevice.xml
gmapbmap.img
gmapprom.img
gmapprom.sum
gmapprom.unl
GUPDATE.GCD
I have upgraded to version 9 maps, and the gmapprom.img file is 1.3G. |
Posted: Thu Aug 16, 2007 7:28 am Post subject: |
Hi Swing,
Thanks to you too.
The only thing that I have done since the backup was taken is updated the software a few times, changed mp3 music files and changed the jpeg image on the welcome screen from the original to one of my own.
After I put my backup copy of the Garmin folder back on the nuvi, I had lost all the extra vehicle icons and voice languages that I had before, but managed to retrieve all these again using the webupdater.
The complete contents of my Garmin folder are as follows:
FOLDER gpx
FOLDER Help
FOLDER poi
FOLDER Vehicle
FOLDER Voice
FOLDER Waypoints
006B047800 BIN File 435 KB
006B048201 BIN File 32 KB
fs_image.ver VER File 1KB
Garmin Device XML Document 20 KB
gmapbmap paint Shop Pro 9 Image 6,604 KB
gmapprom Paint Shop Pro 9 Image 1,137,824 KB
gmapprom.sum SUM File 1KB
GUPDATE.GCD GCD File 8,935 KB
nuvi_ drive Icon
Any further ideas? |
Posted: Thu Aug 16, 2007 7:50 am Post subject: |
I would try a hard reset of the device (explained in the manual). _________________ Please don't be offended if I do not reply to a PM - please ask questions via the forums. |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15146 Location: Bradford, West Yorkshire
Posted: Thu Aug 16, 2007 8:15 am Post subject: |
PSP9 will be set to assume that *.img files are actually graphics files!
in the folder view go to 'tools' then 'folder options...'
then click on 'view' and scroll down and un-tick the 'hide extensions for known file types' and the full file name will then be shown.
bear in mind with this option running if you ever rename a file you will also have to remember to add the extension.
MaFt |
Posted: Thu Aug 16, 2007 12:36 pm Post subject: |
dan12345 wrote: | There is no GMAPPROM.UNL file. |
In that case, I would create one - using Notepad. It should contain the 25 digit Unlock code (with any dashes etc) removed. The finished file will probably be 27 bytes(CR/LF added by Notepad).
The contents of this file seem to be read once, when a change in the maps is detected - and stored elsewhere. After that, it doesn't matter if the file is there or not.
If it's worked, your "Map Info" option should be re-enabled.
Question to others:
I obviously overlooked the fact that the 350 comes with more maps than I am used to seeing Does each region have its own 25 digit unlock code - or is there a Master code for the whole map set.
(ie does GMAPPROM.UNL end up with a long list of codes in it ?) |
Posted: Thu Aug 16, 2007 1:35 pm Post subject: |
The .unl file will contain a single entry, this may be a country unlock code, or a full region (eg Europe) unlock code. However, a 350, which originally shipped with v8 maps will not have, nor need an unlock code, as the unit has a built in unlock code stored elsewhere which confirms it has a license for v8 maps. You only need a .unl code on a Nuvi if you upgrade the maps (to, eg v9). _________________ Please don't be offended if I do not reply to a PM - please ask questions via the forums. |
Posted: Thu Aug 16, 2007 1:46 pm Post subject: |
swing wrote: | You only need a .unl code on a Nuvi if you upgrade the maps (to, eg v9). |
I notice that Dan's file list does not include an Activation.DAT file. Is this also part of the upgrade for maps? |
Posted: Thu Aug 16, 2007 2:25 pm Post subject: |
adrian_anastas wrote: | I notice that Dan's file list does not include an Activation.DAT file. Is this also part of the upgrade for maps? | I don't have an activation.dat to be able to comment on what it is for - I can confirm that I have upgraded the maps, and don't have that file. _________________ Please don't be offended if I do not reply to a PM - please ask questions via the forums. |
Posted: Thu Aug 16, 2007 2:33 pm Post subject: |
Hi Again,
I have tried the hard reset, but still no good.
This is what happens when I turn it on....
The Nuvi 350 copyright notice appears, as it used too. Then there comes the 'loading maps' message and a green progress bar on a white strip. It goes almost halfway, then disappears (used to go all the way). Then there comes some text for a few seconds that reads 'rec routable HWY routable basemap ATL. v2/2.00' After this it is ready to use, but when touching the 'where to?' menu and then trying to choose an option from there, it says 'no map data available'.
the 'my locations' option works, but only shows motorway directions, can't find smaller roads and city streets anymore. Map info button still greyed out in 'map info' menu from settings.
Like Phil says, it's as though it's only reading in the basemap. But I rememember for sure that there was no .unl file on the drive originally (that I could see!) It has City navigator Europe NT v8 (has not been upgraded to v9)
Maybe I'll have to send it back to Garmin for correction....but it would be nice if we could figure it out ourselves |
Posted: Thu Aug 16, 2007 2:43 pm Post subject: |
swing wrote: | ...as the unit has a built in unlock code stored elsewhere which confirms it has a license for v8 maps. |
What I'm suggesting, is that the copy in "elsewhere" has gone missing. Perhaps the Nüvi booted up with no maps at some point and decided to remove a now superfluous code. Given that the 'Green strip' has made an appearance, that kind of suggests that it's treating this as a new map.
(I know the circumstances that make this happen on a C510 - but not a Nüvi. My first C510 shipped with a GMAPPROM.UNL. Garmin replaced the unit for me and the second C510 didn't have the file-I discovered the requirement for it, after a major reset caused by downgrading the firmware. ) |
