vtecsilver Occasional Visitor
Posted: Thu Aug 09, 2007 1:27 am Post subject: TomTom Go (Original) won't find GPS signal since update |
Have an earlier TomTom Go device which was running V4 application. Made a backup of the orginal card on a 2GB card and then upgraded it via TomTom Home to the latest application. Think this was v6.52 which seemed to go through ok. Restarted the TomTom unit, and now it doesn't seem able to find the GPS signals. After waiting 10 minutes it still hadn't found a signal. Trid resetting the unit, but no difference. Inserted the orignal card with v4 application, but still can't find a GPD signal.
Has anyone got any ideas? I was wondering if I need to use GPSfix with the latest update, but I don't think it is available for the original TomTom Go device?
Cheers |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10644 Location: Suffolk, UK
Posted: Thu Aug 09, 2007 6:55 am Post subject: |
It can take some time at the first new fix. It might be that 10mins is not enough.
Have you taken it outside and put it on the top of the car, with a clear view of the sky?
If you have it showing the GPS Status Screen you might have some idea of the progress it's making.
Do you see the satellites display, in grey, and are they nearly at max 'volume'? How many, and are any going Blue? _________________ Richard
TT Via 135 App 12.075: Europe Map v1150 |
Posted: Thu Aug 09, 2007 4:06 pm Post subject: |
Hi - thanks for the quick reply. Haven't tried the unit outside yet, but will give this a go later on, only tried it on first floor near the window. I did change to the GPS/Satellite status screen, and in 10 minutes it hadn't found one satellite last night. Might try resetting it holding the reset for 30 seconds to see if that makes any difference. |
Posted: Thu Aug 09, 2007 7:23 pm Post subject: |
Don't forget the Classic GO only has a Sirf II chipset and so is not as good at picking up satellites as the more modern units. _________________ Richard
Andy_P Pocket GPS Moderator
Posted: Fri Aug 10, 2007 1:38 am Post subject: |
My Go300 (same GPS chipset) NEVER got a satellite fix indoors even near a window. |
NJDav Occasional Visitor
Posted: Sun Oct 07, 2007 5:59 pm Post subject: |
did you manage to fix this fault,i have the same problem, except when i put the old card in it finds the sats in a few minutes like it always had due.
if i can't get it to work i have wasted a chunk of cash on new maps that could have gone towards a new tomtom...
any help on this guys...please
many thanks
NJdav |
Eldar Pocket GPS Moderator
Posted: Sun Oct 07, 2007 10:00 pm Post subject: |
NJDav wrote: | did you manage to fix this fault,
NJdav |
tell us more - what you've done, application version, map version, etc |
