Pocket GPS World :: View topic - TomTom GO 720's Start Shipping
Goto page Previous  1, 2, 3 ... 17, 18, 19 ... 28, 29, 30  Next
Googlebot
PostPosted: Fri Aug 03, 2007 12:07 pm    Post subject: Reply with quote
PC World Business are showing them in stock for same day dispatch - so with 24hr delivery option they should be arriving on Monday (and still under £300 inc).
I sure hope mine arrives on Monday - 6am Wednesday morning is the start of my 3,000 mile trip into/around France.
iPAQ 2110
Kingston 512Mb SD card
Kingston 1gb CF card
Holux CR-100
Soon to be replaced with TT720 (maybe....)
SpeedCam
PostPosted: Fri Aug 03, 2007 12:20 pm    Post subject: Reply with quote
Oldboy wrote:
KGrue wrote:
Has anyone with a 720 had problems with it losing it's settings?
Could this be a problem with the Read Only setting on the CFG File. That has been the problem previously.
Only a shot in the dark.
Yes it looses it setting and I think its due to a file being locked or set to read only. It started when my unit locked up, I reset the unit which then trigger the setup procesure to start, at the end of the setup a message is displayed in the top right hand corner saying ' Unable to store settings, file access error'. It also seems to take a long time to restart as a result of this problem, sometimes hangs requiring a reset.
I'm also seeing the same problem with the 'Help Me!' 'Drive to help' hospitals work correctly, but Doctors, Police, Pharmacy & Dentist all default to France.
PostPosted: Fri Aug 03, 2007 12:22 pm    Post subject: Reply with quote
I think that's because the basic POI's are sh*t.
PaulBt
PostPosted: Fri Aug 03, 2007 12:49 pm    Post subject: Reply with quote
PaulBt wrote:
Looking at the help me menu.
There are garages listed, not my usual one, but several fairly locally.
There are hospitals listed, not all have an A&E (Accident and Emergency) unit which would be I guess what would be required.
The nearest doctor is given as 195miles away (the name looks dutch).
The nearest police station look French, 138miles away.
The nearest pharmacy also looks French 137miles away.
The nearest dentist 195 miles away.
These were my findings on the help locations, not particulalry reliable, and this is one of the major selling points.
Paul
TT720 V8.010, regular audio book user.
WestEuro v805 connected to E90 on O2
TT910 V6.525, TTN5, TTN3, TT on Psion 5mx
DracUK
PostPosted: Fri Aug 03, 2007 1:09 pm    Post subject: Reply with quote
Just received my 720 this morning,great,no problems.
I did have that file access error with a One XL I previously owned.To cure it I copied all files from the sd card to my pc,reformatted the sd card and then copied every thing back and it was cured,no probs after that.
DracUK
pete1336
PostPosted: Fri Aug 03, 2007 1:27 pm    Post subject: Reply with quote
Is the 720 limited to the 100 POI limit as my 510 was previously or has this been expanded at all?
Also, should we now change the forum description and add the 520/720 models to reflect the fact we are now discussing them?
SPORTSMAN
PostPosted: Fri Aug 03, 2007 1:46 pm    Post subject: Reply with quote
Hi peeps fist post here so go easy,ive just got ago 720 from currys and dowloaded the pocket gps speed cams when ive unziped into qv2files where do drop them into when i open tom tom in my computer settings.
MrRubberGloves
PostPosted: Fri Aug 03, 2007 1:56 pm    Post subject: Reply with quote
Did you collect from a store or was it delivered by DHL, if delivered by DHL when did it leave the depot? I ask as I am waiting for a delivery from Currys.
As for the speed cam files, if it's the separate ov2 files, Gatso, Mobile, Red Light etc they along with the bmp files all go in the folder that contains the map files. Mine go into one called the "Western_and_Central_Europe" yours will be something similar.
PostPosted: Fri Aug 03, 2007 1:58 pm    Post subject: Reply with quote
The ov2 and bmp files go in the Western_Europe folder, then configure the Change Preferences/ Manage POI/ Warn when near POI, probably the best guide to follow is the one written for the 910 as the 720 has text to speech, have a read of it Here - Mike
SPORTSMAN
PostPosted: Fri Aug 03, 2007 2:01 pm    Post subject: Reply with quote
Hi mate..I phoned the currys enquiry line 0870 609 7493 and they told me localy which currys had them. Any idea how i load these speed cameras :P
SPORTSMAN
PostPosted: Fri Aug 03, 2007 2:03 pm    Post subject: Reply with quote
Cheers guys..veru helpfull indeed Laughing
Yes - read the guide I linked to in my previous post Rolling Eyes - Mike
PaulBt
PostPosted: Fri Aug 03, 2007 2:12 pm    Post subject: Reply with quote
One of the easiest ways is to use the HOME application; download the speedcameras for HOME and put them into the TomTom/contents folder on your PC (I'm making assumptions). Then in the HOME application pick the middle tab at the top so that it looks in "all sources" and by magic when in the install view a speed camera item should appear. Select this and "install", you will be asked which map it needs to be added to.
You can then go onto the 720 and in "managing POIs" select warn when near and choose how the unit should tell you there is a camera there.
Hope this helps, go to the camera database page to get infinitely more detailed instructions.
lowie
PostPosted: Fri Aug 03, 2007 2:22 pm    Post subject: Nokia 6233 Reply with quote
Hi all. Just been having a play with the new toy and can confirm that the Nokia 6233 works perfectly with the 720.
perky77
PostPosted: Fri Aug 03, 2007 2:26 pm    Post subject: Reply with quote
at long last my order with PCWB has been dispatched this afternoon
Page 18 of 30
