Pocket GPS World :: View topic - New to CoPilot
New to CoPilot
cardiff_gareth
PostPosted: Fri Aug 03, 2007 10:20 am    Post subject: New to CoPilot Reply with quote
Hi Guys (and gals)
I'm new to GPS, my neighbour has given me a XDA Pro that had CoPilot on. The PDA needed a fault fixing and I did a hard reset so software was lost. So, I have 2 boxes, one said CoPilot live 5 and one box said CoPilot 6.
I installed CoPilot 6 onto the PDA and it all fires up, I've had a play and it all seems good.
I've read about bugs in 6. What are these bugs and how can I get around them ?
Also, when you go into the desktop application it gives 4 options, if I select all 4 then they won't fit onto the storage card but I have a 1gb card so could I copy all info from the card supplied on the 1gb and then install all 4 options onto the card if that makes sense, also is it worth doing that Question
Also does CoPilot 6 have speed camera on it or do I have to install something else to it Question
So confusing Exclamation Exclamation Exclamation Exclamation
alix776
PostPosted: Fri Aug 03, 2007 10:59 am    Post subject: Reply with quote
what map data are you trying to put on the 1gb sd card if its the eu map then this will take up a full 1gb card so if there is anything else on the scard then the eu map will not fit .
speed camera can be installed directly in to copilot as .ov2 files it you install the pgpsw speed cameras the select the all in one files and then change the ov2 and bmp file manes to the following
ov2 change to ren pocketgps_uk_. safetycamera_.ov2
this will pull up the copilot speed camera icon and will not take up the whole screen copy the files in the to save folder on the sd card
device Lumia 950 xl
cardiff_gareth
PostPosted: Fri Aug 03, 2007 12:06 pm    Post subject: Reply with quote
where do I get the pgpsw speed camera from ?
Is it ok to copy all info from supplied 256mb card over to the larger 1gb card Question
cardiff_gareth
PostPosted: Fri Aug 03, 2007 12:08 pm    Post subject: Reply with quote
Ah, Just seen the large speed camera sign to the left of the screen Stop it!
