Pocket GPS World :: View topic - 2210 & bluetooth issues !
spectric
PostPosted: Sun Mar 21, 2004 9:35 pm    Post subject: 2210 & bluetooth issues ! Reply with quote
Hi all
Is there a known issue with the 2210 & bluetooth ?
I am having all sorts of problems and it is very hit and miss as to when it decides to work with my Navman 4100 BT GPS.
I get the bluetooth console taking over and then I can only reset the machine.
all the best
Roy
AlanW
PostPosted: Sun Mar 21, 2004 9:49 pm    Post subject: Reply with quote
I've been considering the 2210 myself & discovered that there is a BIOS update just out that cures a few problems. Take a look at http://h18007.www1.hp.com/support/files/HandheldiPAQ/us/locate/105_5721.html
Time flies like a bird. Fruit flies like a banana
Mohan
PostPosted: Sun Mar 21, 2004 10:37 pm    Post subject: I was thinking of buying 2210 and the navman 4410 Reply with quote
Hi I was thinking of buying 2210 and the navman 4410 but reading your problem it's making me think again. How long a did you purchase the items. Someone suggested a solution, did that work?
Please let me know as I am begining to wonder if Tom Tom is a better solution with 2210.
Mohan
SHC
PostPosted: Sun Mar 21, 2004 10:54 pm    Post subject: Reply with quote
I've got a 2210 and rikaline bluetooth gps receiver with TomTom2. You have to follow the instruction exactly or you can mess up, but mine is up and running ok. Applied the registry hack detailed on this site, launch TomTom and 10s later off you go.
Hope this helps.
regards
SHC
spectric
PostPosted: Sun Mar 21, 2004 11:00 pm    Post subject: Reply with quote
Hi all
Was going to download the new BIOS patch but have now lost active sync completely and so no coms with my Pc.
Anybody any ideas on this one ?
Am really starting to wonder if I have made a big mistake with the 2210 & Bluetooth as anything with Microsoft involved is going to have more bugs than you can count.
all the best
Roy
Marky
PostPosted: Sun Mar 21, 2004 11:21 pm    Post subject: Reply with quote
Do a full reset or whatever it is called, hold the two outer butons pressed on the front while presing the reset on the back, hold them for maybe 5 seconds and it will reset ( I think that is the way!)
Install the new update from the link above.
My 2210 is Ok so far with bluetooth since the new bios.
Mark.
spectric
PostPosted: Sun Mar 21, 2004 11:28 pm    Post subject: Reply with quote
Hi there
Have done a full reset several times but cannot get active sync to work.
thanks Roy
all the best
Roy
PostPosted: Mon Mar 22, 2004 8:09 am    Post subject: Reply with quote
If you're all talking mainly about the BT Manager popping up now and again whilst in your application and losing connectivity to the BT GPS, this is a known problem certainly on the 2210 and possibly WM2003 wide. It's a resource issue when the processor/ram is being taxed and the first heavy thing for the OS to shut down is the BT connection.
There were some reg tweaks that some people suggested cured it, some didn't, not sure if the latest ROM PAQ fixes it, haven't really wanted to give it a go because I have far too much installed here.
spectric
PostPosted: Mon Mar 22, 2004 1:01 pm    Post subject: Reply with quote
Hi all
I left the battery out of the 2210 for a few hours & rebooted my desktop. This has got active sync working again and so I downloaded the lastest ROM patch from HP and the BT driver again and reininstalled Navman and Memory map software.
Bingo, it not only works but works very well. I can get four satellites with the Navman 4100 on my desk indoors with no clear view of the sky.
This is most impressive as with my active mice & helix antena I had to at least put them outdoors.
So what is the new version of pocket Pc 2003 all about that microsoft are about to launch ?
I would probabily not bother as if it's working then don't upset it !!
Roy
all the best
Roy
22.055 (29 May 24)
