Pocket GPS World :: View topic - cant warn speed limit in TOMTOM Navigator 6.030 !!!
talkncool
PostPosted: Tue Jul 24, 2007 8:56 pm    Post subject: cant warn speed limit in TOMTOM Navigator 6.030 !!! Reply with quote
Hi All Smile ,
I have recently installed TomTom navigator 6.030 with latest UK n IE map v6.75 which has in built pocketgps speed camera database with all .ogg sound files.
It works fine and it warns on every safety cameras but only problem is it doesnt warn with speed limit for example, if gatso_40 coming in 300 yards, its only warns(speaks) "WARNING GATSO AHEAD" while it should warn(speak)" WARNING GATSO AHEAD SPEED LIMIT 40 MILES PER HOUR".
I dont understand why it happens because I have installed all .ogg sound files in map folder which warns with speed limit like pocketgps_uk_gatso_20.ogg, pocketgps_uk_gatso_30.ogg, pocketgps_uk_gatso_40.ogg and so on I have checked all sound files with ogg player but tomtom doesnt warn with speed limit.
In TomTom Nav v6.030 there is no option to choose sound files in option 'Warn when near POI'
Everything else is working perfect it shows all safety cameras while traveling or even in demo tour. It warns "WARNING REDLIGHT CAMERA AHEAD" or "WARNING GATSO AHEAD" or "WARNING MOBILE CAMERA AHEAD" but without speed limit Sad
Can any one help me? Much appreciated
Thank you
PostPosted: Tue Jul 24, 2007 9:06 pm    Post subject: Reply with quote
Welcome to the forum, it sounds very much like you have installed the consolidated speed camera database which is only capable of letting you know the actual camera type. What you need to do is install the Speed Zoned database instead and configure the warnings again, then you will get the warning of camera type AND speed limit - Mike
JockTamsonsBairn
PostPosted: Tue Jul 24, 2007 9:31 pm    Post subject: Reply with quote
DennisN wrote:
Download drivez from here and do a dump of what you've got in your map folder, then we can inspect it minutely and find your problem.
Jock
talkncool
PostPosted: Tue Jul 24, 2007 11:55 pm    Post subject: Reply with quote
Hi Mike,
thanks for your quick response.
I tried Speed Zoned database too but nothing happened. Same as it does b4 Sad
M i using the right data.chk file???
pls help
tanda
PostPosted: Wed Jul 25, 2007 12:14 am    Post subject: Reply with quote
Hi, If you are using OGG files, you shouldn't be using data.chk files too, its one or the other, and the best way to go is the OGG way. You need the SPEED ZONED OV2 database files, the SPEED ZONED OGG files, and you need the bmp. icons, Put them all in the map folder, and set the distances up etc and away you go. Have a read through here, number 4, it may help.
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=50045
Audi A3 Sline sat nav
talkncool
BGF wrote:
Hi BFG,
Thank you for your response
Here is what i have got in my map folder:
cline.dat
cname.dat
cnode.dat
faces.dat
mapinfo.dat
MapSettings.cfg
pocketgps_uk_gatso_20.ov2
pocketgps_uk_gatso_30.ov2
pocketgps_uk_gatso_40.ov2
pocketgps_uk_gatso_50.ov2
pocketgps_uk_gatso_60.ogg
pocketgps_uk_gatso_60.ov2
pocketgps_uk_gatso_70.ogg
pocketgps_uk_gatso_70.ov2
pocketgps_uk_gatso_tba.ogg
pocketgps_uk_gatso_tba.ov2
pocketgps_uk_gatso_var.ogg
pocketgps_uk_gatso_var.ov2
pocketgps_uk_mobile.ogg
pocketgps_uk_mobile_20.ogg
pocketgps_uk_mobile_20.ov2
pocketgps_uk_mobile_30.ogg
pocketgps_uk_mobile_30.ov2
pocketgps_uk_mobile_40.ogg
pocketgps_uk_mobile_40.ov2
pocketgps_uk_mobile_50.ogg
pocketgps_uk_mobile_50.ov2
pocketgps_uk_mobile_60.ogg
pocketgps_uk_mobile_60.ov2
pocketgps_uk_mobile_70.ogg
pocketgps_uk_mobile_70.ov2
pocketgps_uk_mobile_tba.ogg
pocketgps_uk_mobile_tba.ov2
pocketgps_uk_mobile_var.ogg
pocketgps_uk_pmobile_20.ov2
pocketgps_uk_pmobile_30.ov2
pocketgps_uk_pmobile_40.ov2
pocketgps_uk_pmobile_50.ogg
pocketgps_uk_pmobile_50.ov2
pocketgps_uk_pmobile_60.ov2
pocketgps_uk_pmobile_70.ov2
pocketgps_uk_pmobile_tba.ov2
pocketgps_uk_pmobile_var.ov2
pocketgps_uk_RedLight.ogg
pocketgps_uk_redlight.ov2
pocketgps_uk_specs_20.ogg
pocketgps_uk_specs_20.ov2
pocketgps_uk_specs_30.ogg
pocketgps_uk_specs_30.ov2
pocketgps_uk_specs_40.ogg
pocketgps_uk_specs_40.ov2
pocketgps_uk_specs_50.ogg
pocketgps_uk_specs_50.ov2
pocketgps_uk_specs_60.ogg
pocketgps_uk_specs_60.ov2
pocketgps_uk_specs_70.ogg
pocketgps_uk_specs_70.ov2
pocketgps_uk_specs_tba.ogg
pocketgps_uk_specs_tba.ov2
pocketgps_uk_SPECS_var.ogg
pocketgps_uk_temp.ogg
pocketgps_uk_temp.ov2
poi.dat
tmccodes.dat
traffic.dat
traffic.inc
UK_and_IE_plus_major_roads_of_WE.mid
UK_and_IE_plus_major_roads_of_WE.pna
UK_and_IE_plus_major_roads_of_WE-62e8a279.mac
Hope you may find something
tanda
PostPosted: Wed Jul 25, 2007 12:29 am    Post subject: Reply with quote
If it isn't saying the speed, then you can't have downloaded the speed zoned voice files.
You want the OGG files from here
http://www.pocketgpsworld.com/tomtom-ogg-files.php
I use LIZ, its the 5th set down, the speed zoned set.
talkncool
PostPosted: Wed Jul 25, 2007 12:35 am    Post subject: Reply with quote
Let me try this :o
PostPosted: Wed Jul 25, 2007 5:28 am    Post subject: Reply with quote
Where did you get the warning sounds from? did you name the files yourself.
There is a Gatso 50.ogg file missing from your file set, I would try as tanda mentioned and load up a set of voice files downloaded from this web site. Once installed go back through Change Preferences/ Manage POI/ Warn When Near POI and re-configure all of your warnings - Mike
talkncool
PostPosted: Wed Jul 25, 2007 9:53 pm    Post subject: Reply with quote
Hi Mike, Tanda and all,
Thanks a tonn for your support :D
Its now working perfect.
What I have done is as per yr instruction I have replaced ogg files and reconfigured the whole settings and it works. I think there must be some probs with that ogg files.
I have just tested so sorry for replying it late.
Anyway, I am happy now :D :D
Cheers guys
PostPosted: Wed Jul 25, 2007 11:02 pm    Post subject: Reply with quote
Delete these files - they are not required in the speed zoned set of cameras.
If you think you might get the wrong ones, leave them there - they're not doing any harm, this is just a tidying up exercise.
