philpugh Lifetime Member
Posted: Mon Jul 23, 2007 2:44 pm Post subject: |
Dave-H wrote: | Thats the idea [though that grid ref seems to be a digit short] |
Its a conventional 12 digit OSGB ref. (i.e. AAeeeeennnnn) giving you 1 metre accuracy - more than good enough for GPS systems even with EGNOS corrections applied. _________________ Phil |
Posted: Mon Jul 23, 2007 4:43 pm Post subject: |
When I tried this I fired up the Nuvi 310D and got a position fix at the rear of my house in OSGB format, I then dropped a marker falg on to Memory Map on the PC and typed in the Garmin derived coordinates, the flag was a considerable position North of where my house is actually located, I will measure the distance later when I get home and can use the PC but it was quite a way out.
By the way can you not run Memory Map on the SPVc500, I have used it on SPVc600 quite well, but you need to be using Memory Map version 5 for it to work on MS Smart Phone, and to be honest it is not as versatile as MM on a PDA. Have a look at the T Mobile MDA Compact - III or O2 XDA Orbit as these work very well as phones with inbuilt GPS, all you then need is some software to use on the device - Mike |
Dave-H Occasional Visitor
Posted: Mon Jul 23, 2007 7:17 pm Post subject: |
philpugh wrote: | Dave-H wrote: | Thats the idea [though that grid ref seems to be a digit short] |
Its a conventional 12 digit OSGB ref. (i.e. AAeeeeennnnn) giving you 1 metre accuracy - more than good enough for GPS systems even with EGNOS corrections applied. |
DOH !!! What a berk !
Didn't realise bottom line of numbers was remainder of ref - just saw ST xxxxx. |
mg46783 Occasional Visitor
Posted: Mon Jul 23, 2007 8:41 pm Post subject: |
[quote="Dave-H"]Right, i think PDA is the way to go, and stick Tom-Tom 6 on it.
Dave -- Im not sure and Im sure someone will correct me if Im wrong - but I dont 'think' you can run TT 6 on a PDA. I think ( again ) it has to be V5
Mikeg |
oddsock Pocket GPS Verifier
Joined: May 01, 2004 Posts: 706 Location: Monmouthshire
Posted: Mon Jul 23, 2007 9:38 pm Post subject: |
[quote="mg46783"] Dave-H wrote: | Right, i think PDA is the way to go, and stick Tom-Tom 6 on it.
Mikeg |
Hi,welcome to the forum.I think you will find that TTNv6 will run well on quite a few different PDA's including my ageing ipaq 2210
Dave _________________ TomTom one v1,tomtom one v 3,TT Start20,Garmin Oregon 300,Nuvi 300
Garmin Quest |
Posted: Mon Jul 23, 2007 11:11 pm Post subject: |
Dave[/quote]
Hmmm - Just mine then !! Typical
mikeg |
Posted: Tue Jul 24, 2007 8:12 am Post subject: |
TomTom version 6 will run on PDA devices that use the operating system of Windows Mobile 2003SE or newer, there is a problem using TT6 on earlier operating systems with the screen rotate function.
I use it on my PDA based phone with integral GPS receiver (HTC Artemis) - well worth considering a device of this type - Mike |
Calomax Lifetime Member
Posted: Tue Jul 24, 2007 8:52 am Post subject: |
Quote: | Dave -- Im not sure and Im sure someone will correct me if Im wrong - but I dont 'think' you can run TT 6 on a PDA. I think ( again ) it has to be V5
I'm running TTN 6.03 on an iPAQ 1940 with no trouble at all. I've even had TT support which surprised me :o .
If you look at TT's website http://www.tomtom.com/products/category.php?ID=2&Language=1 you'll find that TT6 is available as the TomTom/HP Navigation Pack on an HP iPAQ hw6915 direct from TT _________________ TT Go Essential
Posted: Tue Jul 24, 2007 8:54 am Post subject: |
mikealder wrote: | TomTom version 6 will run on PDA devices that use the operating system of Windows Mobile 2003SE or newer, there is a problem using TT6 on earlier operating systems with the screen rotate function.
Mike.Out of interest what would you say was the advantage of having the screen view rotate to landscape when navigating?
Garmin Quest |
Posted: Tue Jul 24, 2007 9:16 am Post subject: |
Right.......... it will be a Mio P350, just cant decide on TT6 or Mio-map 3v.
Whats best?? |
Posted: Tue Jul 24, 2007 3:22 pm Post subject: |
Just ordered it.
P350 with TT6.
Stuck with TT as its what i'm used to.
Not from GPS ltd alas, cheaper elsewhere by £8 and with a free case :D [plus here out of stock and i dont want to wait]
Ta for all help lads 8)
Posted: Tue Jul 24, 2007 4:41 pm Post subject: |
oddsock wrote: | mikealder wrote: | TomTom version 6 will run on PDA devices that use the operating system of Windows Mobile 2003SE or newer, there is a problem using TT6 on earlier operating systems with the screen rotate function.
Dave |
I don't think there is anyadvantage - with direction-up display then it makes more sense to have traditional portrait display. However majority of PNDs are landscape - so I guess most people think the opposite to me. Maybe it's to do with the 'additional info' that is placed around the edges of the map/route. _________________ Phil |
Posted: Tue Jul 24, 2007 6:40 pm Post subject: |
[quote=
I don't think there is anyadvantage - with direction-up display then it makes more sense to have traditional portrait display. However majority of PNDs are landscape - so I guess most people think the opposite to me. Maybe it's to do with the 'additional info' that is placed around the edges of the map/route.[/quote]
Yes thats what I thought about the direction up and portrait display but I did not want to be missing out by keeping my old steam job going,
Garmin Quest |
Posted: Wed Jul 25, 2007 7:38 pm Post subject: |
What other software will i need to use it as a hand held GPS reciever to check location in OSGB?
Any [free or cheap] off road mapping i could also use on it?
quote]
Right, got P350 with TT6.
As above, what software do i need to load in order to use it as a conventional GPS reciever [displaying current position in OSGB?]
Where do i find said software, is it free [or cheap]?
Same again with off road mapping, suggestions? |
Posted: Thu Jul 26, 2007 9:27 pm Post subject: |
[quote="Dave-H"]
quote]
Anyone?
someone must know |
