Pocket GPS World :: View topic - TT 720 & TT 910
TT 720 & TT 910
carcuscrae
PostPosted: Wed Jul 18, 2007 3:56 pm    Post subject: TT 720 & TT 910 Reply with quote
Ok, I have a TT 910 but I do like the look of the new TT 720's therefore I am thinking of getting one. As I like to have the maps from the US from the 910, is there anyway I could get an SD card and load them on there and use on the new 720?
PostPosted: Wed Jul 18, 2007 4:59 pm    Post subject: Reply with quote
Same question as HERE really, although with the extra step of copying from your 910's harddrive.
I assume you still get a product code number for the map when you buy a 910?
carcuscrae
PostPosted: Wed Jul 18, 2007 5:53 pm    Post subject: Reply with quote
Thanks for the reply.
Yes I still have the product code so I assume I can then just copy it using TT home? Or do I have to do something else to get it off the HD?
PostPosted: Thu Jul 19, 2007 1:16 am    Post subject: Reply with quote
I hope you've already got a backup on your PC! - So you should be able to simply copy and paste it from there to the new unit (SD card or internal memory if it's big enough.
If you haven't done a backup, PLEASE do one straight away before you even think of doing anything else.
Don't use Home, it has a tendency to miss bits out of it's backups, use the instructions HERE
carcuscrae
PostPosted: Thu Jul 19, 2007 9:37 am    Post subject: Reply with quote
Thanks for your help with the backup instructions. I do already have backups but I wasn't aware of the problems with TT Home.
Now I have my full backup do I just have to copy the US maps to the SD Card or are there other files required as well?
PostPosted: Thu Jul 19, 2007 1:10 pm    Post subject: Reply with quote
Can't say for certain, as the 720 isn't officially released yet, so very few people have seen one... Smile
On the "ONE" new edition with the 1GB internal memory, it uses EITHER the memory OR the SD card, so if you put a map on a card you also have to add all the system files. (Daft!).
However, PGPSW have had a preview of the 720 and I read on here that TomTom have sorted it out so the 520/720 can use both the memory and the SD card simultaneously, so you would only need the map itself..
thebinman
Banned
PostPosted: Thu Jul 19, 2007 1:54 pm    Post subject: Reply with quote
Really? I find that hard to believe but I suppose I may be proved wrong (one day) Wink
PostPosted: Sat Jul 21, 2007 12:58 am    Post subject: Reply with quote
Told to us on this forum by one of the PGPSW team who has an early review model. Too tired to search out the quote tonight!
Tim Buxton
PostPosted: Sat Jul 21, 2007 7:27 am    Post subject: Reply with quote
It was I and I can confirm that the model I have (sample, not review) can use both internal and external memory simultaneously. However, as this is a sample and not a production unit, this might change. Let's hope not.
Tim
FazerUK
PostPosted: Sat Jul 21, 2007 4:24 pm    Post subject: Reply with quote
TomTom would not let you have two active maps on two device as far I am aware
TomTom Go 700,
with External Antenna, External Mike
App v7.160, OS:2324, GPS v1.21, Boot 5.4201
Western_Europe-Map v650.1127
PostPosted: Sat Jul 21, 2007 5:44 pm    Post subject: Reply with quote
You can have as many activated maps on the device as you want, but only one map will be set as active (the one currently in use, switching between activated maps is easy - Change Preferences/ Manage Maps/ Switch Map) - Mike
Tim Buxton
PostPosted: Sat Jul 21, 2007 6:30 pm    Post subject: Reply with quote
How do you mean?
Tim
FazerUK
PostPosted: Sat Jul 21, 2007 7:42 pm    Post subject: Reply with quote
Tim Buxton wrote:
How do you mean?
If hes talking of moving his maps from the 910 and putting them on the 720 when he guys it.
TomTom Go 700,
22.055 (29 May 24)
