Holmwood Occasional Visitor
Posted: Tue Jul 17, 2007 10:03 pm Post subject: TomTom GO 510 - startup tom-tom sound |
I have bought a new 2Gb SD card for my TTG 510. I loaded the navigator s/w and maps manually. OK. TT Home now thinks it is a 710 but everything seems to work fine. But on startup it does not play the "tom-tom" sound that it does with the original TT card. Anyone know where the start-up sound is stored and if that sound can be replaced by something else?
By the way, I noticed various posts about splash screens. I have successfuly used some digital camera pictures for both startup and closedown splash screens. Used GIMP2 to rescale them and copy them into the original splashw.bmp and suspendw.bmp. Nice. :D |
DennisN Tired Old Man
Posted: Tue Jul 17, 2007 10:43 pm Post subject: |
You only get the TT drums when you reboot, not at every startup. Dunno what it's called or where it is. _________________ Dennis
Two of them are obesiting!! |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10644 Location: Suffolk, UK
Posted: Wed Jul 18, 2007 6:19 am Post subject: |
The drum roll is hard coded into the software. _________________ Richard
TT Via 135 App 12.075: Europe Map v1145 |
Andy_P Pocket GPS Moderator
Posted: Wed Jul 18, 2007 11:19 am Post subject: |
Also, to put your mind at rest, the TT 510 and 710 are identical hardware - only the supplied maps are different - so Home always identifies them both as a 710. |
rjm2k Occasional Visitor
Posted: Wed Jul 18, 2007 1:06 pm Post subject: |
Andy_P2002 wrote: | Also, to put your mind at rest, the TT 510 and 710 are identical hardware - only the supplied maps are different - so Home always identifies them both as a 710. | Mine first identified it as a 710, but then started saying it's a 510 ! What happend to the 610 ?! |
Deus Regular Visitor
Posted: Wed Jul 18, 2007 3:03 pm Post subject: |
not sure what happened to the drum roll, mine never does it since changing the splash screen. But then again, I'm addicted to splash screens. :D |
Posted: Wed Jul 18, 2007 3:09 pm Post subject: |
rjm2k wrote: | Mine first identified it as a 710, but then started saying it's a 510 ! |
They must have tweaked something in the later versions of Home then.
Deus wrote: | not sure what happened to the drum roll, mine never does it since changing the splash screen. |
As Dennis says, on a normal switch on you shouldn't get the drum roll. It only plays if the unit has had to re-boot from scratch for any reason (connected to PC, SD card removed etc.) |
tanda Lifetime Member
Joined: Aug 21, 2005 Posts: 617 Location: Gloucester UK
Posted: Wed Jul 18, 2007 3:17 pm Post subject: |
It does it if you take the SD card out, then back in again. It did it on mine when I was fiddling with it, when I first had it, hasn't done it again. Don't go taking the SD card out when TomTom is writing to the card, in fact, switch off, before removing the card, but the TomTom is never off , even when you switch it off. _________________ Audi A3 Sline sat nav |
Posted: Wed Jul 18, 2007 9:36 pm Post subject: |
Thanks all for the information. Removed and replaced the new SD card and, right enough, a drum-roll...issue solved. :D |
