Pocket GPS World :: View topic - Navman F20 - Can you change the speed camera warning beep ?
keithjeffrey
PostPosted: Sat Apr 28, 2007 10:54 pm    Post subject: Navman F20 - Can you change the speed camera warning beep ? Reply with quote
In the absence of a section for the Navman F20 , I have posted this question here ( If the mods. want to move it somewhere more appropriate then go for it )
Does anyone know if it is possible to change the standard speed camera warning beep to another noise / word of your choosing ?
Keith
TomTom GO 730T App 8.392 (1909/091109) , W and CE 2GB v835.2419
wizard2552
PostPosted: Sat Jun 02, 2007 1:50 am    Post subject: f20 chime change Reply with quote
no keith dont think so
john Laughing
TheM
PostPosted: Sun Jul 15, 2007 10:47 pm    Post subject: Re: Navman F20 - Can you change the speed camera warning bee Reply with quote
It's not officially supported but you could try -- some models allow it, some don't (not sure about F20, I think that 530 did but not 100%). If you connect to the device and check ini files in MyPOI directory, there is a "soundfile" entry in there (if it isn't then try adding it, e.g. "soundfile=default.wav"). Try replacing with different wav file -- if it still plays default sound than this option is not supported on your model. If you get just silence than option is probably supported but format needs to match exactly, ditto for distorted sound. You can get format info if you copy one of the wav files from the unit onto your Windows PC, right click on it and check Summary tab.
wizard2552
PostPosted: Sun Jul 15, 2007 10:55 pm    Post subject: Reply with quote
how do you connect to the device please.
Regards john Wink
TheM
PostPosted: Mon Jul 16, 2007 12:12 am    Post subject: Reply with quote
Buy Connectivity kit for F Series from Navman.
If shop is out of stock try Google.
TheM
PostPosted: Mon Jul 16, 2007 4:32 am    Post subject: Reply with quote
I found the original post claiming that it is possible to assign individual sounds to POIs and gives some details on correct format. It is quite old.
If you decide to give it a try do check the file format first as described since it could have changed. I did hear that later this individual sound functionality was disabled on some devices but not sure which ones -- could very well be that F20 was affected. However, even if is disabled on F20 it should still be possible to change that one sound to something else.
TheM
PostPosted: Mon Jul 16, 2007 6:08 am    Post subject: Reply with quote
Here's some advice for 530 and 520 as well.
Looks the same -- the only difference is that 520 has CHK files while 530 doesn't (just like F20), but you should only be modifying WAV and INI files anyway (and you can skip INI files if you don't care about having different sounds for different POIs).
PostPosted: Mon Jul 16, 2007 7:33 am    Post subject: Reply with quote
As the F20/ F30 only connect to the PC via the Navman connectivity kit you would have to use this software to install anything to the device, you cannot use Active Sync so I am not too sure the linked methods will work - Mike
Ratbert
PostPosted: Thu Jul 19, 2007 11:24 am    Post subject: Reply with quote
Check this thread for clues...
