Pocket GPS World :: View topic - Go 910 and Specs
Go 910 and Specs
rtimms
PostPosted: Fri Jun 29, 2007 2:54 pm    Post subject: Go 910 and Specs Reply with quote
Hope this is the right place to ask this question..
Earlier today i downloaded the data base and have been busily setting it all up.. It all seemed very simple and following the excellent guide to setting it up on the 910 made it so easy.. However i have realised that for some reason there is no sign of the specs cameras in my manage poi's.. I have manageed to set up all the other types of cam but theses arent here.. Why would they not be showing up?? They have definitely been downloaded and extracted onto the units hard drive as i checked that the files were there myself!!
Am i missing something glaringly obvious??? Any help greatly appreciated!!!!!
Robbie
PostPosted: Fri Jun 29, 2007 3:09 pm    Post subject: Reply with quote
Which format database have you got? If Speed Zoned then you should see a number pocketgps_uk_specs_xx.bmp and .ov2 files.
Also this could be because you have too many POI categories installed, do you have many other POIs installed?
rtimms
PostPosted: Fri Jun 29, 2007 3:18 pm    Post subject: Reply with quote
darren thanks
I have no idea how many other poi categories are installed.. Whatever the system came with..
What i cant work out is why the pocket gps gatso's and mobile cams and provisional mobile cams and red light cams have all come up and i have edited them but as i say there is no sign of the specs in the manage poi menu..
As i said before i know the specs files are on there the same as the other types of cam because i can see them on the hard drive of the tom tom!!!
How can i delete some other poi categorys if you think that may help??
rtimms
PostPosted: Fri Jun 29, 2007 3:20 pm    Post subject: Reply with quote
p.S. Have also just looked in the enable/disable points of interest button on the preference menu which lists all the poi categories and the specs is the only one not to show on there aswell!! I downloaded the full speed zoned database by the way!
PostPosted: Fri Jun 29, 2007 3:25 pm    Post subject: Reply with quote
Ok, can you tell me how many pocketpgs files are on the 910 in the map folder, you can browse it using Explorer from your PC.
rtimms
PostPosted: Fri Jun 29, 2007 3:29 pm    Post subject: Reply with quote
Hi Darren
There is 62 in total.. Half of these are bmp files and half are ov2 files
PostPosted: Fri Jun 29, 2007 3:35 pm    Post subject: Reply with quote
Hmm, well that's correct. And no other POI files in the same folder, just the PocketGPS ones? If so, might be worth downlaoding and copying them over again?
rtimms
PostPosted: Fri Jun 29, 2007 3:38 pm    Post subject: Reply with quote
No Darren there is loads and loads of other poi files in that folder... I just told you the amount of pocket gps files.. Should there be no other poi files in that folder then??
PostPosted: Fri Jun 29, 2007 3:43 pm    Post subject: Reply with quote
I ask because there is a limit of 100 POI files. Go above that and POI's start randomly disappearing from the menu's and maps.
The 100 POI limit does not include those POIs built-in to the system i.e airports, parking etc. This only refers to those you have installed yourself. Any POIs in the map folder would normally have to have been installed by you.
If you're happy doing so, remove all the POIs in the map folder except the PocketGPS ones and test. Be sure to only remove POIs though, not the map files themselves. Just files ending with .bmp and .ov2.
rtimms
PostPosted: Fri Jun 29, 2007 3:48 pm    Post subject: Reply with quote
Ah i see.. So the files that are in there currently are probably the files from Tom Toms speed cam system which are no longer required.. I will attempt to delete these..
Should the specs automatically start showing if this is right or will i need to reinstall???
PostPosted: Fri Jun 29, 2007 3:53 pm    Post subject: Reply with quote
Assuming it's too many POIs then yes they should become visible.
rtimms
PostPosted: Fri Jun 29, 2007 4:00 pm    Post subject: Reply with quote
Darren there is also some ov2.ver files which appear to be the same file names as all the files i just deleted... Any ideas on these???
PostPosted: Fri Jun 29, 2007 4:07 pm    Post subject: Reply with quote
No idea, can you email me one?
rtimms
PostPosted: Fri Jun 29, 2007 4:09 pm    Post subject: Reply with quote
Thankyou very much for your help darren.. I would never have figured that one out myself... The specs poi's have started showing now!! Yippee!! Just so i know how many different pocket gps categories should be showing on the manage poi's???? All i have to do now is try and download the sound warnings!!!!!!!
PostPosted: Fri Jun 29, 2007 4:12 pm    Post subject: Reply with quote
Including the pMobile cameras there are 31 seperate POIs in total.
