Pocket GPS World :: View topic - Which iPaq can I use with a Navman 3450 sleeve?
CS
PostPosted: Wed Mar 17, 2004 11:36 pm    Post subject: Which iPaq can I use with a Navman 3450 sleeve? Reply with quote
My Compaq iPaq 3800/Navman 3450 sleeve went totally ballistic today. All was working beauitfully up to last night when I put the final touches to my set up by adding Niels' UK Postcode Finder and CheckPOInt v2.0.2. This complemented Tomtom 2 , Navman Serial Driver 3.1.6 plus POI Edit v3. The last thing I did was to mess around with changing the hard button defaults (may have been a big mistake?). Turned it back on again this morning only to find I had seemingly lost TT2, CheckPOInt, Post Code Finder. Navm,an Serial Driver and even the File Explorer icon though programme still seem be there when viewed through Active Sync 3.7.1). Check in Remove Programs and all seemed to be still loaded. Then I suddenly realised that neither Storage Card - 128 MB CF card (with all maps on etc) in Navman nor 256 MB SD card (empty) in iPaq were being recognised by the iPaq. Also rather oddly the battery light was pulsing away even though it was connected to the cradle (first time I had noticed that).
Any idea folks?
Also as a last resort may upgrade my iPaq to more up to date with latest OS on (WM2003 or 4 (if it exists?) but will any iPaq fit my Navman 3450 sleeve or am I restricted to certain models? If so which?
icsys
PostPosted: Thu Mar 18, 2004 12:15 am    Post subject: Reply with quote
iPAQ H3700, H3800 and H3900 series
icsys
PostPosted: Thu Mar 18, 2004 12:20 am    Post subject: Reply with quote
Maybe the battery power was fully drained?
Not sure on the 3800 but on the 2210 the battery light pulsates when in the cradle to show the battery is charging. when it is steady the battery is fully charged.
CS
PostPosted: Thu Mar 18, 2004 12:26 am    Post subject: Reply with quote
You may well be right but would that make it "lose" TT2, plus 3.1.6 serial driver, CheckPOInt and UK postcode finder and not be able to recognise either SD card in iPaq or CF card in Navman sleeve?
In replt to yours - Yes mine's the same. It pulses when charging in the cradle or via the in car charger but I've never seen it flash when unconnected from a source.
CS
PostPosted: Thu Mar 18, 2004 12:32 am    Post subject: Reply with quote
Hi Icsys
Thanks for the iPaq details. I guess these are not generally for sale anymore having just looked at the latest product range on the HP site. The only ones mentioned are h5550, h4150, h2210, h1940 and h1930. I suppose none of these would fit my 3450 sleeve?
icsys
PostPosted: Thu Mar 18, 2004 1:11 am    Post subject: Reply with quote
If the light is on all the time it sounds like a fault on the ipaq.
A quick search suggests those models are discontinued. You may be able to pick up a second hand one if it turns out yours is faulty.
Telboy
PostPosted: Thu Mar 18, 2004 11:21 am    Post subject: Reply with quote
CS,
Have a look on ebay. There are a number of IPAQ 3800 series listed.
CS
PostPosted: Thu Mar 18, 2004 6:17 pm    Post subject: Reply with quote
Telboy/Icsys
Thanks guys.
Tim Buxton
PostPosted: Fri Mar 19, 2004 3:40 pm    Post subject: Reply with quote
CS,
CS wrote:
Hi Icsys
Navman's website also lists the 5550 as being compatible. I certailnly hope it is, as mine should be here on Monday. Happy
Tim
icsys
PostPosted: Fri Mar 19, 2004 8:19 pm    Post subject: Reply with quote
Not according to their product description here?
http://www.navman-europe.com/product_details.php?id=AA005214
But I hope for your sake it's wrong.
Tim Buxton
PostPosted: Fri Mar 19, 2004 8:45 pm    Post subject: Reply with quote
The page you link to does indeed state that it *is* compatible with the 5550, so I'm smiling. Laughing
(And I quote:-)
The Navman GPS 3450 is compatible with the following iPAQ Pocket PC's H3600, H3700, H3800, H3900, H5150, H5450 and H5550 series iPAQs
Tim
icsys
PostPosted: Fri Mar 19, 2004 10:02 pm    Post subject: Reply with quote
Tim
Apologies if the information I provided is wrong. There is no intention to mislead anyone. just trying to be helpful.
CS
You may be able to buy a NEW ipaq. However,
I would suggest that you double check this info with whoever you decide to purchase the kit from as virtually all the retailers I have visited suggest that the 3450 sleeve will only fit the ipaq 3600 3700 and 3900 series.
Having said that, I would expect Navman to know which PPCs their product works with. Their glossy product brochure does not state the ipaq5550 is compatible.
