Pocket GPS World :: View topic - Speed Cameras for Kenwood DNX 7200
simonk1969
PostPosted: Thu Jun 28, 2007 8:43 pm    Post subject: Speed Cameras for Kenwood DNX 7200 Reply with quote
I have a Kenwood DNX 7200 in Car entertainment system. It advises to update the speed cameras using the Garmin webupdater but this seems to fail to detect my sd card, it did detect it originally but it won't now. The card is working fine and is detected within windows.
I have purchased a one year subscription to Pocket GPS.
Does anyone have one of these units and can advise on the correct procedure to update the unit.
Thanks in advance
Simon
famarsh
PostPosted: Thu Nov 22, 2007 11:10 pm    Post subject: Reply with quote
Just got this same system & there are NO instructions on how to load the unit once you have used POI loader & put everything on the SD card, I put in the DNX 7200 & nothing happens , PLEASE someone how on earth do you load poi to this unit.
simonk1969
PostPosted: Fri Nov 23, 2007 9:24 am    Post subject: Reply with quote
If I remember correctly you need to put the sd card in and then switch to NAV mode and it should read the poi's in.
Hope that helps
Simon
tanda
PostPosted: Fri Nov 23, 2007 4:22 pm    Post subject: Reply with quote
I haven't got your Sat Nav, But on mine, you have to go into preferences, and enable them, and set up an audible warning, do you need to do this on yours?
Audi A3 Sline sat nav
famarsh
PostPosted: Fri Nov 23, 2007 6:39 pm    Post subject: Reply with quote
With regard the above two posts I've tried everything, It does nothing when you put the SD card in & there's no option under NAV to install or look for a card, The instruction manual for this unit is terrible, all it tells you is where the SD slot is & then to follow the instructions but there arn't any.
simonk1969
PostPosted: Fri Nov 23, 2007 7:27 pm    Post subject: Reply with quote
I've just done a update on mine and it works fine.
grab the POI's you require and unzip them and put them in a folder on the PC. Then with POI Loader from Garmin locate your POI's in the folder and then POI Loader should put them all onto the SD card.
Take the SD card and put into the SD slot in the unit. Pres the NAV button to change to the Navigation system and it should automatically change to a screen that says there are new POI's on the SD card then press the screen to confirm you want to load these into memory on the unit. Job Done !!
famarsh
PostPosted: Fri Nov 23, 2007 8:25 pm    Post subject: Reply with quote
That's what I've been doing with no luck at all , look's like I've got a duff unit Crying or Very sad
PostPosted: Fri Nov 23, 2007 8:28 pm    Post subject: Reply with quote
Can you try using a different SD card, perhaps the one you have is not being seen by the Kenwood due to access speed or the type of format - Mike
famarsh
PostPosted: Fri Nov 23, 2007 8:41 pm    Post subject: Reply with quote
I haven't actually tried a different card, Can anyone recommend any particular type that has been proven to work & how should I format it FAT FAT32 NTFS?
PostPosted: Fri Nov 23, 2007 8:52 pm    Post subject: Reply with quote
can you also confirm that the files have copied correctly? on teh sd card you should have: Garmin/POI/poi.gpi
this is the file that is created by POI Loader
famarsh
PostPosted: Fri Nov 23, 2007 9:28 pm    Post subject: Reply with quote
Yep I definitely have that.
I've borrowed another SD card from my neighbour & tried that also with no luck however his card is slightly different as it has 2 extra conections on the back (9 in total) where as mine only has 7, what are the differences & what sort of SD card should I be using?
famarsh
PostPosted: Fri Nov 23, 2007 9:43 pm    Post subject: Reply with quote
Also can anyone confirm if there's an option on the DNX7200 to disable/enable the SD slot , I have looked but maybe I missed something because this is getting very anoying now Crying or Very sad
famarsh
PostPosted: Sat Nov 24, 2007 12:30 pm    Post subject: Reply with quote
WooHoo all sorted Very Happy , Went into town this morning & got a new SD card & it worked first time , Not sure why the others didn't work as they are fine in a camera. Anyway I'm a happy bunny now & thanks for all the help Smile
PostPosted: Mon Nov 26, 2007 11:28 am    Post subject: Reply with quote
technology... ya gotta love it!!
