PhilGarmin Lifetime Member
Joined: Nov 07, 2006 Posts: 55 Location: Kidsgrove, Staffordshire, UK
Posted: Mon Jun 18, 2007 10:21 am Post subject: Garmin Nuvi 660 updated firmware v3.8 |
Garmin have updated both the 660 firmware to v3.80 and the bluetooth firmware to v2.8.
660 firmware updated to 'increase screen sensitivity'. Cant feel any difference though.
Bluetooth firmware updated using webupdater but had no notes.
No operational differences yet found.
Good Luck all. _________________ Garmin DriveSmart 76 with Alexa |
GJF Frequent Visitor
Posted: Wed Jun 20, 2007 11:07 am Post subject: Re: Garmin Nuvi 660 updated firmware v3.8 |
PhilGarmin wrote: | Garmin have updated both the 660 firmware to v3.80 and the bluetooth firmware to v2.8.
Good Luck all. |
I have so far found the same - no obvious difference.
If anything the sensitivity on the screen seems worse as i'm tapping a couple of times rather than once as before!  _________________ TomTom Go 60
Garmin Nüvi 660, Firmware v4.90
Drive-Smart GPS with Loader v1.4.16
HTC Advantage X7500 MS 6.1 Tchart Speed Sentry
Satmap Active 10, Software v1.16
Fuzion 32 HUD Bluetooth GPS receiver |
redsquirrel Occasional Visitor
Joined: Jan 23, 2007 Posts: 58 Location: Chandlers Ford, UK
Posted: Fri Jun 22, 2007 9:05 am Post subject: Re: Garmin Nuvi 660 updated firmware v3.8 |
GJF wrote: | If anything the sensitivity on the screen seems worse as i'm tapping a couple of times rather than once as before!  |
I appear to have lost the ability to use the end of a pen as a stylus. Nothing happens and I now have to use my finger
The warning for a couple of speed cameras I passed yesterday never sounded. As I haven't checked all the 660's settings I cannot yet blame it on the firmware upgrade. _________________ Red Squirrel
Garmin Nuvi 660FM
DriveSmart (pending disposal ) |
philpugh Lifetime Member
Posted: Fri Jun 22, 2007 2:11 pm Post subject: Re: Garmin Nuvi 660 updated firmware v3.8 |
redsquirrel wrote: | GJF wrote: | If anything the sensitivity on the screen seems worse as i'm tapping a couple of times rather than once as before!  |
Perhaps the update was to ensure there were less chances of mis-keying? I notice you need to use deliberate finger pressure now. This may stop me mis-keying the GARMIN-lock number and having to switch off and on - which I see as a good thing. _________________ Phil |
Hamie Regular Visitor
Posted: Sun Jun 24, 2007 10:53 pm Post subject: Re: Garmin Nuvi 660 updated firmware v3.8 |
philpugh wrote: | redsquirrel wrote: | GJF wrote: | If anything the sensitivity on the screen seems worse as i'm tapping a couple of times rather than once as before!  |
Perhaps the update was to ensure there were less chances of mis-keying? I notice you need to use deliberate finger pressure now. This may stop me mis-keying the GARMIN-lock number and having to switch off and on - which I see as a good thing. |
Hmm... Hope so. The touch screen on mine is pretty pants really.. I get annoyed at the number of times the 'U' key comes up when I press something else... Often something on the otherside of the screen, so I know it's not just my cack handedness. |
Posted: Mon Jun 25, 2007 10:41 am Post subject: |
Sounds like a fault to me - give Garmin a call. _________________ Phil |
Posted: Mon Jun 25, 2007 10:42 am Post subject: |
Posted: Mon Jun 25, 2007 3:03 pm Post subject: |
philpugh wrote: | Sounds like a fault to me - give Garmin a call. |
Yeah... Garmin Support... An OxyMoron I think... I'd expect their support for this to be about as good as their support for the GTM-21. i.e. nonexistent. |
PaulJSmith Regular Visitor
Posted: Mon Jun 25, 2007 4:48 pm Post subject: |
My screen is now too "unsensitive" since this update. I have called garmin to complain but I don't expect a reply anytime soon.
As for the bluetooth update - the only thing it seems to have done is messed up the call logs. They used to reflect only called received/made/miised from the Nuvi. Now it seems to pick up the lists from the phone but on my phopne the list bears no resemblence to the list presented on the Nuvi.
What a major leap forward from Garmin. Keep up the good work. |
Posted: Mon Jun 25, 2007 5:03 pm Post subject: |
Not noticed that change. It's still appears to record the calls made and received via the nuvi - but I will keep my eye on it
I did have to reload the contacts list from my older Nokia phone (6680) after the BT upgrade - as I did when I first paired it. My newer N72 does it automatically at each connection, due to a Symbian app that needs to run on it to get functionality with the Parrot chip set in the nuvi. _________________ Phil |
Posted: Mon Jun 25, 2007 9:23 pm Post subject: |
Hamie wrote:
Quote: | I get annoyed at the number of times the 'U' key comes up when I press something else... |
I get this when i add postcodes and address's to my favorites, it often mistakes a letter for "U" even when well away from the position of U.
Since the update I have to admit on two favorites added, this hasn't happened yet. :D
philpugh wrote:
Quote: | I notice you need to use deliberate finger pressure now. |
That's how i see it. _________________ TomTom Go 60
alexberry Occasional Visitor
Joined: Nov 15, 2006 Posts: 17 Location: Edinburgh, Scotland
Posted: Mon Jun 25, 2007 10:10 pm Post subject: |
It seems that the Bluetooth Firmware update has resolved issues with the Samsung D900 - it now seems to pair up and work OK.
Hooray!
Alex. _________________ Alex Berry,
Edinburgh, Scotland |
Posted: Tue Jun 26, 2007 6:44 pm Post subject: |
More than deliberate finger pressure for me. Sometimes the unit moves on the mount I have to press so hard. Also, using the finger to drag the map around is much harder now.
Pants if you ask me. Preferred it the way it was. |
Posted: Tue Jun 26, 2007 7:44 pm Post subject: |
PaulJSmith wrote: | More than deliberate finger pressure for me. Sometimes the unit moves on the mount I have to press so hard. Also, using the finger to drag the map around is much harder now.
Makes you wonder if the programmers actually use one of these things on a day-to-day basis, or only at their desk. The UI is crap for a driver (No space for speed, yet space for a bloody button bringing up the MP3 player!), no traffic except via multiple button pushes, traffic sorted by distance from a random endpoint, rather than distance from your position and now impossible to use touch screen... |
Posted: Wed Jun 27, 2007 11:31 am Post subject: |
I'm now getting used to this and am beginning to prefer it.
I do have a Brodit mount so not having a problem with the mount moving, but adding an address or favorite is a lot easier than before.
After the initial setup i prefer not to fiddle with the unit after i have set off unless i'm forced to, so keep my "fingers" to the steering wheel. _________________ TomTom Go 60
