sjaspinall Occasional Visitor
Posted: Sat Jun 23, 2007 5:54 pm Post subject: |
I've done all that...i've just tried the single file folder the Pmobile File went over fine but got the same message trying to transfer the sc file. |
jrsound Occasional Visitor
Posted: Sun Jun 24, 2007 9:29 am Post subject: |
That was it - the 39 file limit.
I removed Portugal and off it went!
Thank you.
John. |
Posted: Thu Jun 28, 2007 7:44 pm Post subject: |
Does anyone have any idea to my problem as posted above? |
![](modules/Forums/images/avatars/gallery/Sphere_animated_small_neg2.gif)
Posted: Thu Jun 28, 2007 7:51 pm Post subject: |
Try downloading the database again and once unzipped it should copy to the map folder on the MDA it certainly does on my device, just make sure its connected via Active Sync.
As another option if you have a card reader try copying the files to the card in the reader thus bypassing Active Sync all together - Mike |
dg0106085 Occasional Visitor
Posted: Fri Jul 13, 2007 12:55 pm Post subject: |
I have TomTom installed on my Nokia N73. I never had a problem with TTN3 or TTN5 on my PDA. But there isnt a Great Britain folder in my directory. Is this the correct file that I am looking for?
Thanks in advance.
DaveG |
Oldboy Pocket GPS Moderator
![](modules/Forums/images/avatars/gallery/waveform.jpg)
Posted: Fri Jul 13, 2007 1:42 pm Post subject: |
dg0106085 wrote: | Is this the correct file that I am looking for? | Can you tell us why you are looking for a particular File, or do you mean Folder?
We might be able to give some advice if you explain what you are trying to achieve. _________________ Richard
Posted: Fri Jul 13, 2007 1:50 pm Post subject: |
Oldboy wrote: | dg0106085 wrote: | Is this the correct file that I am looking for? | Can you tell us why you are looking for a particular File, or do you mean Folder?
We might be able to give some advice if you explain what you are trying to achieve. |
Sorry, I typed it wrongly. I dont have the Great_Britain-Plus folder in any of my directory on my phone. I was wondering what folder I should install the speed camera files to. |
Posted: Fri Jul 13, 2007 1:57 pm Post subject: |
The camera Files go into the Map Folder. It's name will depend on which Map you have. It is usually on the SD Card.
Does the Navigation software work OK? _________________ Richard
Posted: Fri Jul 13, 2007 2:41 pm Post subject: |
Thanks. The software works fine although it was installed by the previous owner.
I have pasted the files into any potentially correct folder without any luck. I find it strange though, I know any of my other TomToms installed need the folder that your guide says. |
Posted: Fri Jul 13, 2007 2:43 pm Post subject: |
Sorry another point to add:
App version 6.010 (7640)
GPS driver v1.20
Map: 'Western_Europe'
v660.1256
Language: English UK
I will add the cameras to that map to see if it works. BRB |
Posted: Fri Jul 13, 2007 2:46 pm Post subject: |
OK Problem fixed. I should have tried this earlier.
On another note; is the Great Britain Plus Map more accurate than this Western Europe Map? |
Posted: Fri Jul 13, 2007 5:37 pm Post subject: |
Probably not, as the GB-Plus map was a V5 Map which has now been replaced by the UK and Ireland Map (which I believe also contains the MRE). _________________ Richard
Posted: Fri Jul 13, 2007 5:45 pm Post subject: |
Thanks Oldboy. Help is appreciated. |
Ezy162 Occasional Visitor
Posted: Mon Jul 16, 2007 1:28 am Post subject: cant get this to work :( |
Ok, i have tomtom mobile 5. I have a different folder for each map, so great britian, france, belenux etc. I just downloaded the europe camera database. When i paste the content of the folder into each map folder nothing comes up on tomtom, why is this?? |
Posted: Mon Jul 16, 2007 6:45 am Post subject: |
Please don't Double Post.
I've replied to your other Thread HERE. _________________ Richard
