Pocket GPS World :: View topic - Garmin 310D question
popasmurf
PostPosted: Fri Jun 08, 2007 7:34 pm    Post subject: Reply with quote
Tim Buxton wrote:
Unless Navman change the way they sell maps for this device, you're stuck with buying them on a new card, I guess.
As for the speed alert, alter it here:-
Preferences, Navigation, Safety Alerts, Audio or Visual (or both).
Remove ticks as necessary.
You can also set the speed at which alerts show or sound.
Hi Tim, I have a Garmin 310D,is tipossible to set the speed at which alerts sound on it please?Thanks Question Embarassed
Tim Buxton
PostPosted: Fri Jun 08, 2007 7:49 pm    Post subject: Reply with quote
I've split this from a topic in the Navman section. I'm afraid I have no idea as to the answer, so can anyone else chip in?
Tim
PostPosted: Fri Jun 08, 2007 8:15 pm    Post subject: Reply with quote
The alert speed that the 310D notifies you of is set within the POI file assuming you are using the PocketGPSWorld Speed Camera Database, these values can be altered by opening the POI file using Excel and altering the @XX (where XX is the speed value, for each camera type). If you are using the as supplied Cyclops database then I am not too sure what it offers in terms of configuration as I don't use it.
Your Nuvi has no way of knowing the actual speed limit for the road you are on so it will not warn of over speed, it can only be used to warn of speed camera position AND relevant speed when set up correctly.
As this is a Nuvi device I will move the thread to the Nuvi section, others who use the device you have are more likely to comment - Mike
22.062 (12 Jun 24)
