Joined: Aug 31, 2005 Posts: 15422 Location: Bradford, West Yorkshire
Posted: Mon May 21, 2007 1:18 pm Post subject:
Does it take into account the RedSpeed cameras like the PGPSW one does? also, the PGPSW files for iGo has heading data which isn't available in the other asc downloads
Yes, it does if the RedSpeed camera files are provided in the database;
e.g. pocketgps_uk_redspeed_30.asc, pocketgps_uk_redspeed_40.asc etc., or similarly named files in Ov2 format.
However, it now also extracts cameras based on the description as well as the file name, so it extracts the PGPSW RedSpeed cameras correctly. The settings for this can be modified in the "Settings.ini" file.
MaFt wrote:
The PGPSW files for iGo has heading data which isn't available in the other asc downloads
This information is not in any of the PGPSW Ascii or Ov2 downloads so cannot be extracted. If this is included in the Ascii files then it will be extracted. See the Readme file in the download for more information.
linknet
Posted: Tue May 22, 2007 12:49 pm Post subject:
nearly every format has camera type but this is within the actual files - i.e. gatso, truvelo, monitron, redspeed are all in the 'gatso' file - we don't have a separate redspeed file - we have enough already!
as for heading data the only formats using this at the moment are: iGO text format, MioMap v3, and Drive Smart
MioMap v3 is a specific format that needs creating via some custom made software and is not 'readable' and DriveSmart is a bizarre twist on a csv using semi-colons instead of commas and commas for the decimal points...
for reasons of file size and bandwidth we only include data that is needed for the specific format - i.e. the only units that can use heading data are those mentioned above so there is no point adding extra data that can't be used for the other formats.
Hi linknet,
good work :-)
Thnks for credit!!
"Credits are due to the creator of Miomap_v3-autovelox_updater-v3.3, which I understand to be Ervius"
bye!!!
Hi linknet,
good work :-)
Thnks for credit!!
bye!!!
Hi ervius, nice to hear from you. All credit where credits due !
I might have a look at exporting to MioMap format.
Do MioMap still use the ".upd" file format ? If so, could you let me have details of the file structure ? You could PM me if you don't want to post it.
Regards
linknet
Joined: Mar 01, 2004 Posts: 290 Location: Northampton
Posted: Fri May 25, 2007 8:31 pm Post subject:
The above link to download appears not to be active, does anyone have a copy they could pm me or a better link? _________________ Please follow me on twitter @mdyson1968
I forgot to tell you that I'm spanish to give you the idea of the problem that was in windows regional settings, sorry...
An idea, can you put a button to launch a .bat file for renaming all files after conversion ? many people must rename many asc files to assign speed to cams and it's a bit slower to do by hand.
My apologies also, I hadn't realised that the regional settings would cause a problem.
Can you post the names of the files before and after renaming.
Page 1 of 4
