Pocket GPS World :: View topic - Convert ozf2
Convert ozf2
vladuna
PostPosted: Thu May 03, 2007 5:18 am    Post subject: Convert ozf2 Reply with quote
Is there a way how to convert ozf2 + map files back to jpg/tiff/png + map files? thank you.
barryd
PostPosted: Thu May 03, 2007 11:02 pm    Post subject: Reply with quote
Open the ozf map in OziExplorer on the PC then on the menu select File - Save Map to Image File - Colour Image.
Barry Davies
vladuna
PostPosted: Fri May 04, 2007 4:40 am    Post subject: Calibrate again? Reply with quote
Thank you, Barry. It works Smile but it is necessary to calibrate BMP/PNG again, isn't it? Crying or Very sad
barryd
PostPosted: Fri May 04, 2007 9:28 am    Post subject: Reply with quote
Yes, but it's easy enough just to copy across the calibration values from the original ozf map, isn't it? You could do either of the following:
    1. Open the ozf map in OziExplorer then on the menu select "File - Check Calibration of Map" and note down the values. Use them to calibrate your new bmp map.
    2. Open the ozf map file in Notepad, edit the second line to the name you want displayed for your map and the third line to the full path and filename of your bmp file, then Save As the new bmp map file.
Barry Davies
22.055 (29 May 24)
