Pocket GPS World :: View topic - BT looses connection- good news..
golmert
PostPosted: Sun Mar 07, 2004 10:01 pm    Post subject: BT looses connection- good news.. Reply with quote
Hi all,
Since the 2215 BT manager keeps on loosing connection with all sorts of GPS receivers , I tried installing the following free software:
http://www.handango.com/PlatformProductDetail.jsp?siteId=1&jid=7289E5975EF61FE88875F2AE35171EC7&platformId=2&productType=2&catalog=0§ionId=0&productId=96903.
This bypasses the BT manager.
I installed it and got rid of the annoying dissconnections, it works perfect now!
I recommend those who still suffer from that phenomena to try it, seems worth it.
golmert
PostPosted: Sun Mar 07, 2004 10:06 pm    Post subject: The right link Reply with quote
If you cannot open the above link try doing search at Handango for rthe following:BtRegTweak
PostPosted: Sun Mar 07, 2004 10:17 pm    Post subject: Reply with quote
Or use this link http://www.handango.com/PlatformProductDetail.jsp?productId=96903
Be aware that this mod works only on PPC2203 PC's that use the Widcomm BT Stack. There are also implications if you have multiple applications that may require access to BT services.
golmert
PostPosted: Sun Mar 07, 2004 10:21 pm    Post subject: Reply with quote
Which implications?
i am using it both with a BT activesync and the BT GPS and it seems to work fine..
PostPosted: Sun Mar 07, 2004 10:27 pm    Post subject: Reply with quote
Read the earlier thread which discussed this Tweak here.
golmert
PostPosted: Sun Mar 07, 2004 10:47 pm    Post subject: Reply with quote
Just tried it once again-
with BT GPS there is autodetection and thats great.
With my laptop- I connect to my laptop through the BT manager as I used to do and that seems to work just fine.
PostPosted: Sun Mar 07, 2004 10:51 pm    Post subject: Reply with quote
I'm not suggesting it won't work for you, just that in some circumstances bypassing the Bluetooth Explorer will or may cause issues Smile
golmert
PostPosted: Sun Mar 07, 2004 10:52 pm    Post subject: Reply with quote
It seems that after installing the software it creates number of BT tweeks accordiing to the existing BT cconnections you configured on your BT Manager. In that case, in order to avoid a mismatch of detecting devices all you have to do is configure only one of the tweeks to autodetect and the rest will be connected manually through the BT Manager.
22.054 (22 May 24)
