Pocket GPS World :: View topic - Speed Camera Database available for Garmin GPSR systems
WiRED
PostPosted: Mon May 08, 2006 1:50 pm    Post subject: Reply with quote
Curious wrote:
Is there any way that the units (i.e. 2610, iQues) can be set up to give Audible as well as Visual warnings
I can't speak for the Quest, but the 2610 certainly does not have any facility for proximity alerts.
/WiRED
Skippy
PostPosted: Mon May 08, 2006 2:35 pm    Post subject: Reply with quote
In a word, No.
The Quest 2 does proximity alerts using the new POI loader but the older units don't do it.
Some units like the old GPS-V had proximity alerts but they were limited to 10 waypoints so they weren't any use for speed cameras.
Gone fishing!
missing_user
PostPosted: Mon May 08, 2006 5:55 pm    Post subject: Reply with quote
The iQue 3600 has the ability to have visual and audible warnings for the Speed Camera database.
Some 'Welshman' has listed the instructions in the left navigation bar!
I also use the 'overlay' method [visual only]
Curious
PostPosted: Thu May 11, 2006 6:41 pm    Post subject: Reply with quote
Thanks for the replies.
wrxseeker
PostPosted: Sat May 13, 2006 10:25 am    Post subject: Reply with quote
Help - can someone post a link as I cant find the download for the overlay.
Skippy
PostPosted: Sat May 13, 2006 11:14 am    Post subject: Reply with quote
When you pay your subscription to allow you to download the camera database you get the option to download the Garmin version.
(Apologies to strumble, the iQue 3600 does indeed do alerts, it's the 2610 that doesn't. Although I think the 27xx series do.)
Gone fishing!
gangalee
PostPosted: Sat May 13, 2006 2:34 pm    Post subject: Reply with quote
I have used WiRED's speed camera data-base before on my IQue & 2610 both running Mapsource navigator v7, I found the data overwhelming as it included mobile sites, and I only wanted the fixed camera sites + red-light cameras. As a trucker I also wanted to include a low-bridge data base, so I wrote a converter in C++ to convert *.csv or *.asc files to *.mp format. I can then use the excellent shareware program cgpsmapper to import ANY converted data to my units. I now have visual representation as an overlay. To get audible alerts I use the same data imported/converted previously using birdwatch & wayque as the alert software.
Gangalee
LGV Class 1, Garmin Streetpilot 2720
Mapsource 2010
Lowbridge-Speed Camera Data
ronnietemp
PostPosted: Fri May 26, 2006 9:48 pm    Post subject: Text to speech? Reply with quote
I've just bought a Garmin nüvi 360 (which is fab, by the way) and would like to install the speed camera POIs, but could someone please tell me if this software will alert me to a nearby speed camera, either by speech or audible alarm, or do I need to keep an eye on the the screen to see if there's a symbol coming up?
Thanks in advance
Ronnie
mardyboy
PostPosted: Mon Jun 12, 2006 1:29 pm    Post subject: Reply with quote
I have an IQue3600. I have loaded camera details and they show up in my address book. How can I get them to give me allerts please? All I seem to be able to do is see them on the display as waypoints.
Regards
Martin
missing_user
PostPosted: Mon Jun 12, 2006 4:10 pm    Post subject: Reply with quote
Six posts above, is a posting relevant to you!
paynes1
PostPosted: Tue May 01, 2007 2:34 pm    Post subject: Reply with quote
I have downloaded the GPRS overlay onto my PC and then onto my Quest 1. I cannot see the cameras on the Quest although it shows City Navigator Europe 8 and Euro Poc ticked in the MapSource info page. It also shows PGPSW Uk, UK Europe ticked when I select Euro Poc.
I have tried using various viewing scales and purposely ridden by cameras to see if they are shown, but to no avail.
I have asked this on another page but didn't get a reply so it might have been the wrong page.
I am still very new to using the kit, so any advice gratefully received.
missing_user
PostPosted: Tue May 01, 2007 4:24 pm    Post subject: Reply with quote
Quite often they are Navaid icons on the Garmin units.
Set them up as Navaids in the options not waypoints or POI!!!!!!!!! :D
Let me know if that solves it!
paynes1
PostPosted: Tue May 01, 2007 6:39 pm    Post subject: Reply with quote
Thanks for taking the time to answer Strumble.
I cannot find the options that you suggest on the machine.
Reading the advice on the forum about how these GPRS maps work, it seems that once loaded from the PC with the Garmin maps they are 'transparent' maps that should be visible with the Garmin maps showing through-therefore I should (I think) be able to see both.
I can only see the Garmin map without any cameras. The map info on the kit shows that the relevant GPRS map is loaded.
Thanks again
Steve P
missing_user
PostPosted: Tue May 01, 2007 7:20 pm    Post subject: Reply with quote
http://myweb.tiscali.co.uk/walterwright/screens.html
The unit is shown here with the overlay.
'Skippy' is very respected member here on this website, so as he uses or used the Quest 1 in the screenshot, try asking him for help.
Send him a Private Message.
I still am of the opinion that you have not found/selected the Marine option, but then again, I'm still learning!! :D
WiRED
PostPosted: Tue May 01, 2007 9:41 pm    Post subject: Reply with quote
Hi paynes1,
I'm looking at the Quest manual at the moment, page 35. Have a look at the Point Tab in Map Setup. It looks like it is possible to turn on/off the display of POIs using the 'Hide Above' setting. If that's set to Off, POIs will never display. Also, look at the Map Tab, and make sure that the Detail level isn't set too low. If you don't see the POIs when its set to Normal, try upping it to High (or whatever the higher settings are - manual doesn't say).
There are usually settings like the above on most Garmin units, and they often cause this sort of problem with the overlay.
/WiRED
Page 2 of 4
