Pocket GPS World :: View topic - Is it easy to transfer full map to new storage card?
pauley
PostPosted: Tue Mar 02, 2004 9:46 pm    Post subject: Is it easy to transfer full map to new storage card? Reply with quote
Hi, I am using an ipaq 2210 and Tomtom 2. I want to get a bigger storage card and was wondering whether I can just transfer the data on one card across to another card? I didn't really want to reinstall if at all possible.
Thanks a lot
Paul
PostPosted: Tue Mar 02, 2004 10:25 pm    Post subject: Reply with quote
If you have a card reader attached to your PC then it's a simple process of copying the map folder off the card, onto your PC and back onto the new storage card.
If you don't have as card reader then it is the same process albeit a lot slower, dock the PPC, browse to the storage card, copy the map folder to your PC, undock, replace storage card, dock once more and copy the map folder (and its contents!) onto the new card. No re-installation necessary Thumbs Up
pauley
PostPosted: Tue Mar 02, 2004 10:30 pm    Post subject: Reply with quote
Thats a great help Darren, thanks for your quick response mate.
Regards
Paul
pauley
PostPosted: Fri Mar 05, 2004 9:25 pm    Post subject: Reply with quote
OK, got my new 256mb cf card. I copied the map folder from my sd card to my PC and then transfered to my new card. The PPC shows it has transfered but when I launch Navigator on PPC it tells me that it "cannot find navigator(or one of its components). Make sure the path or filename are correct and all the required libraries are available".
Do I need to be doing something else?
Thanks a lot
Paul
PostPosted: Fri Mar 05, 2004 9:38 pm    Post subject: Reply with quote
Was TomTom installed to main memory? On your original storage card was there anything else on it apart from the map folder?
The error suggests that Navigator may have been installed to the storage card, if you insert the original card does the error still ocurr?
pauley
PostPosted: Fri Mar 05, 2004 9:41 pm    Post subject: Reply with quote
No it wors fine on the old card. I think in hindsight I installed it all onto sd card.
What are my options now? Am I best just reinstalling the whole lot?
PostPosted: Fri Mar 05, 2004 9:44 pm    Post subject: Reply with quote
If it was installed to SD card then just copy the entire contents of the original SD card to the new card and you should be fine Thumbs Up
pauley
PostPosted: Fri Mar 05, 2004 9:59 pm    Post subject: Reply with quote
Thanks for your time. Just trying now.
Paul
sparkster
PostPosted: Sat Mar 06, 2004 4:43 pm    Post subject: Reply with quote
I done the same pauley (copied maps from a cf card to an sd card),,, tom tom still works and see's the maps,, i also copied maps from tt and smart st to a new 256 cf card and have no probs m8,, so you should have very few (if any) probs
pauley
PostPosted: Sat Mar 06, 2004 5:02 pm    Post subject: Reply with quote
Yeah I've got it up and running now.
Thanks a lot everyone.
22.055 (29 May 24)
