Bojarski Occasional Visitor
Joined: Mar 07, 2006 Posts: 2 Location: North Staffordshire
Posted: Wed Apr 11, 2007 3:54 pm Post subject: Do i3 and nuvi 300 use same in-car power leads? |
I am thinking of upgrading my Garmin, the i3 is hard wired into tha car electrics (still using the original plug) When I pass on my old unit to my brother can I just swap leads? |
swing Pocket GPS Verifier
Joined: Nov 04, 2003 Posts: 2225 Location: Bedfordshire, UK
Posted: Wed Apr 11, 2007 7:02 pm Post subject: |
The Nuvi range use a mini usb connector, I don't believe this is the connector used by the i3, but if it is, then it will work fine. _________________ Please don't be offended if I do not reply to a PM - please ask questions via the forums. |
Posted: Wed Apr 11, 2007 7:03 pm Post subject: |
Sorry, I should clarify this - this is true for the Nuvi 300 you mention, but other newer models in the range use a different connector, which is definitely not compatible with the i3. _________________ Please don't be offended if I do not reply to a PM - please ask questions via the forums. |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15154 Location: Bradford, West Yorkshire
Posted: Sat Apr 14, 2007 1:06 am Post subject: |
my nuvi 350 uses the same lead as my i3... |
Posted: Sat Apr 14, 2007 10:23 pm Post subject: |
Thanks to all for your help, I'll check before I buy. |
Posted: Mon Apr 16, 2007 12:26 am Post subject: |
MaFt wrote: | my nuvi 350 uses the same lead as my i3... |
or at least i've been using both with either with no problems!
MaFt |
