Pocket GPS World :: View topic - TT 510 Will NOT switch off
rwhitby
PostPosted: Thu Apr 05, 2007 8:59 pm    Post subject: TT 510 Will NOT switch off Reply with quote
My TT 510 Will no longer switch off it just keeps rebooting the only way to switch it off is to press the reset switch every time I want to swich off any one any ideas
Ray
PostPosted: Thu Apr 05, 2007 9:03 pm    Post subject: Reply with quote
Press and hold the reset button down for thirty seconds then see if it will behave itself - Mike
Oldboy
PostPosted: Thu Apr 05, 2007 9:12 pm    Post subject: Reply with quote
You could also try Reset Factory Settings in Change Preferences.
rwhitby
PostPosted: Thu Apr 05, 2007 9:24 pm    Post subject: Reply with quote
Thanks Mike and Oldboy just did that and still NO joy
Ray
StanStill
PostPosted: Fri Apr 06, 2007 9:06 am    Post subject: Reply with quote
I had the same problem when I updated the software. The only way I could get round it was by using a different SD card even though it had worked perfectly before (a sandisk). If you have a spare give it a try.
thebinman
Banned
PostPosted: Fri Apr 06, 2007 9:38 am    Post subject: Reply with quote
Maybe you're holding the power button down for too long?
Just hold down till the Suspend splash screen shows then let go.
Robin2
PostPosted: Fri Apr 06, 2007 11:35 pm    Post subject: Reply with quote
I had exactly the same thing happen last month after a firmware upgrade via TomTom Home. None of the suggetions from this forum worked (reset for 30 seconds, restore factory default settings,etc) and the Restore Backup function on TomTom One didn't work either. Fortunately I had an independent backup which I had made by copying the card into a folder on my desktop. I formatted the card and copied this backup and it all worked properly again.
I had cause to use the same backup folder again this evening. I had tried to use TomTom Home to create a backup prior to loading the latest PGPSW Safety camera database. Part way through, the process stalled, but I was unable to turn the device off properly from the PC. I closed TomTom Home (which was not responding) and turned off my device using the button, but it wouldn't work, in spite of trying the 30 second reset routine. Eventually I formatted the SD card again (which had evidently become corrupted when TT Home stalled) and copied my backup from the desktop - it's all fine again now
Robin
TomTom One v3 Europe, Navcore 7.903, Western Europe 835.2420
Satmap Active 10
Plus a lot of other PDA GPS kit, seldom used
RQ
PostPosted: Sat Apr 07, 2007 5:55 am    Post subject: Reply with quote
I haven't had this problem yet but will remember for the future.
However, I have 3 SD cards:-
1. The original SD card kept in the box
2. Copy 1 - working OK
3. Copy 2 - a copy of 1 but used for updating
Whilst it is good to have backups on the PC (and I do) - I keep the spare SD with the TT in case of problems with the SD installed. But if I have any problems I immediately switch cards. When I get home - its format and copy the good one back to the formatted.
In fact my wife uses the TT1 most of the time and I don't want her getting lost.
Regards
RQ
TT1v3 6.560 1713 UK&NI 660.1199
TTG700 6.520 1387 MoWE 660.1219
PostPosted: Sat Apr 07, 2007 8:06 am    Post subject: Reply with quote
SNAP !!! This is exactly what I do. The other thing I do is my backups on the PC are ALL done by copying with Windows Explorer (set to show all files and extensions) - I wouldn't trust TT Home backups for all the tea in China! I "allow" TT Home to autorun when I connect to PC, but minimise and use Explorer. If I didn't need Home for OS updates I'd uninstall it.
Robin2
PostPosted: Sat Apr 07, 2007 10:00 am    Post subject: Reply with quote
Yes, for brevity I didn't give the whole story, but I also keep the original TT card in the box for fallback if necessary. The backup I keep on the desktop is the most recent satisfactory version and has all the latest itineraries and POI warning settings, which I don't want to have to redo unnecessarily.
When things go wrong, it's a great comfort to insert the original TT card and find that it works OK - I then know that the problem is corrupt software in my copy card.
Robin
Satmap Active 10
zark
PostPosted: Sun Apr 08, 2007 5:03 pm    Post subject: Reply with quote
good tips... last night my One wouldn't switch off... without restarting straight away.
Restored backup, seems fine now... Funny how it's been fine for months though.
23.084 (27 Aug 25)
