Pocket GPS World :: View topic - So, my dad is returning his TomTom One tomorrow
blizeH
PostPosted: Thu Apr 05, 2007 5:50 pm    Post subject: So, my dad is returning his TomTom One tomorrow Reply with quote
... due to a faulty speaker.
I remember spending quite a bit of time (mostly thanks to the excellent advice given on here may I add!) setting it up so that the speed camera information was present and so that I had audio alerts.
Basically, I want to know how to get this onto the replacement TomTom that he's hopefully going to pick up tomorrow, and want to be sure I'm getting the correct files across.
As a precaution I've copied all of the files as a backup, but I believe that only the .ov2 and .ogg files need to be copied across, but I'm not entirely sure? Any advice would be ace, thanks!
thebinman
Banned
PostPosted: Thu Apr 05, 2007 6:26 pm    Post subject: Re: So, my dad is returning his TomTom One tomorrow Reply with quote
[quote="blizeH] but I believe that only the .ov2 and .ogg files need to be copied across, but I'm not entirely sure? Any advice would be ace, thanks![/quote]
Correct, either d/l them again or copy them directly into the map folder.
AFTER DOING A BACK-UP OF COURSE!
PostPosted: Thu Apr 05, 2007 7:06 pm    Post subject: Reply with quote
You need the folowing POI files for them to work correctly:
.ov2 (which contains the locations)
.ogg (which is the audio warning sound)
.bmp (which is the icon)
All the files related to the speed cameras will start with a file name of "pocketgps_uk......" these are the ones to copy to the new device - Mike
RQ
PostPosted: Fri Apr 06, 2007 6:43 am    Post subject: Reply with quote
You might also consider creating a poi file from your favourites - you can then transfer that over.
RQ
TT1v3 6.560 1713 UK&NI 660.1199
TTG700 6.520 1387 MoWE 660.1219
PostPosted: Mon Apr 09, 2007 10:39 am    Post subject: Reply with quote
If he's getting the same "flavour" of ONE (i.e. regional or Europe) then just copying "MapSettings.cfg" will get all the favourites, Home location, etc. across.
The only (recently discovered) issue with copying this file across between different machines is that you may lose the ability to select Dutch postcodes if you take the file from a UK only machine and put it on a Europe-wide one (I think!).
23.084 (27 Aug 25)
