Pocket GPS World :: View topic - mio 168 connector part number
pag1ele
PostPosted: Mon Apr 24, 2006 10:59 pm    Post subject: mio 168 connector part number Reply with quote
Can anyone find a replacement part number for the charging/activesync connector on a mio 168 board. finding it impossible to source a connector part number.
Border_Collie
PostPosted: Tue Apr 25, 2006 1:08 am    Post subject: Reply with quote
It's appears to be happening all too often with the 168 but remember it came with a 2 year guarantee. A mate of mine, and several others in these forums, had the same problem. Contact Mitac and they'll send a 'jiffy bag' or similar for you to return it for repair. I believe the turn-around time is less than a week.
It appears they put a new board in so you'll have a different device code and have to re-activate.
pag1ele
PostPosted: Tue Apr 25, 2006 10:02 pm    Post subject: Reply with quote
problem is I bought it second hand. Have opened the case and the inner part of the connector has broken away. Could re-solder the inner part and then use epoxy to make it solid but it would be nice to get a new replacement connector if possible.
Border_Collie
PostPosted: Wed Apr 26, 2006 1:02 am    Post subject: Reply with quote
Maybe you could get an answer from http://www.apexlaptops.co.uk/ it's worth a try.
pag1ele
PostPosted: Wed Apr 26, 2006 10:52 am    Post subject: Reply with quote
Thanks for your help. Tried them but he will only sell 30 of them, not good business sense. Will keep trolling the internet and see if I can strike lucky.
Leif
PostPosted: Wed Apr 26, 2006 9:21 pm    Post subject: Reply with quote
You can buy it here
http://www.parts4pdas.de/cgi/websale6.cgi?Ctx=%7bver%2f6%2fver%7d%7bst%2f3eb%2fst%7d%7bcmd%2f0%2fcmd%7d%7bm%2fwebsale%2fm%7d%7bs%2fparts4pdas%2fs%7d%7bl%2fDeutsch%2fl%7d%7bctx%2ffef0e8e5%2fctx%7d%7bmi%2f16%2d2%2fmi%7d%7bpi%2f3S671%2d001%2fpi%7d%7bpo%2f1%2fpo%7d%7bfc%2fx%2ffc%7d%7bmd5%2f9e9169ed53503a50a6c185f88cf88277%2fmd5%7d
for 29 euro. If the link is bad go to http://www.parts4pdas.de, Yakumo, Yakumo Delta 300 GPS. It's the same hardware as Mio 168.
Pc-Mobile
PostPosted: Fri Apr 28, 2006 2:51 pm    Post subject: Reply with quote
I do not think you can possibly change the connector yourself.
If you have to and get stuck with finding one. We might be able to help.
Pc-Mobile
http://pc-mobile.net/gps.htm
pag1ele
PostPosted: Fri Apr 28, 2006 3:38 pm    Post subject: Reply with quote
Have desoldered the connector and cleaned up the contacts on the board with de-solder ribbon. The connector breaks because the centre tongue is not crimped very well to the outer shield. If you remove the outer shield and re-assemble the connector and crimp the tongue with some long nose pliers it is more secure and should last considerably longer. Will probably add a little adhesive to strengthen the connector. seems to me that this is a problem with mio's connector supplier. No wonder they are replacing them under warranty if they are still in the guarentee period. thanks for the offer but fingers crossed it will be ok. If I can get hold of a camera I will post some photo's.
pag1ele
PostPosted: Fri Apr 28, 2006 3:41 pm    Post subject: Reply with quote
Also thanks to Leif for the link. But after taking it appart I think the connector is repairable.
maxqa
PostPosted: Sun Mar 11, 2007 12:50 pm    Post subject: Reply with quote
I too am looking to source the Mio 168 USB/Charger sync connector.
Does anyone know of a source within the UK and have any experiences of fixing it themselves.
Any help / advice greatly appreciated.
many thanks
Max
Nixkap
PostPosted: Fri Mar 23, 2007 2:29 pm    Post subject: Reply with quote
You can also buy this connector in Poland for £25
Check this link : http://techgsm.com/System_Connector_MDA_XDA_MIO_168_original,6491.html
I've done it my self yesterday on a MIO 168, and it works fine Laughing , I'll try to take some pictures when I'll have time
GO GO GO Do it Folks ...
Pc-Mobile
PostPosted: Fri Mar 23, 2007 5:16 pm    Post subject: Reply with quote
If you write to us, we can get you one for US$10-15 plus shipping.
Pc-Mobile
Pc-Mobile
PostPosted: Sat Mar 24, 2007 5:57 am    Post subject: Reply with quote
If you do need a female connector we have it available for $12.50.
http://pc-mobile.net/connectors.htm
Pc-Mobile
maxqa
PostPosted: Thu Mar 29, 2007 10:44 pm    Post subject: Reply with quote
Thanks for the links / info guys.
Managed to get a skilled colleague to resolder the original one and now all OK again.
