Pocket GPS World :: View topic - tom tom 710 help desperate
highlander317
PostPosted: Fri Mar 23, 2007 7:06 pm    Post subject: tom tom 710 help desperate Reply with quote
Borrowed the bosses tt710 this morning, drove a few miles to do a job kept the tt safe and secure. When i tried to turn it back on for the journey home i cant turn it on. The greeen power light comes on and so does the green light on the cigarette charger. Tried everything anyone got any idea? Desperate for help as i need it for the morning
PostPosted: Fri Mar 23, 2007 7:51 pm    Post subject: Reply with quote
Have you tried a reset of the device? - see Here for the reset switch location, if a short press doesn't cure the problem try 30 seconds. Also removal of the memory card and pressing the power button for ten seconds has been mentioned (I would try them in that order) - reset switch first - Mike
highlander317
PostPosted: Fri Mar 23, 2007 7:55 pm    Post subject: Reply with quote
will using the reset switch completely reset the device?
PostPosted: Fri Mar 23, 2007 7:56 pm    Post subject: Reply with quote
You won't loose any settings or data, it should recover the device so it boots up though - Mike
thebinman
Banned
PostPosted: Sat Mar 24, 2007 9:42 am    Post subject: Reply with quote
Similar to ALT/CTRL/DEL on your PC
highlander317
PostPosted: Sat Mar 24, 2007 5:25 pm    Post subject: Reply with quote
worked a treat thanks guys
