Pocket GPS World :: View topic - TomTom one, with traffic & bluetooth headset
robodan
PostPosted: Fri Mar 23, 2007 4:08 pm    Post subject: TomTom one, with traffic & bluetooth headset Reply with quote
Can it be done???
will phones only accept one device at a time???
will changing the pass key help at all???
PostPosted: Fri Mar 23, 2007 4:40 pm    Post subject: Reply with quote
Depends on the phone and its support for multiple BT devices. I use a PocketPC Phone and that can happily talk to a BT GPS and BT Headset at the same time. However many normal phones cannot.
robodan
PostPosted: Fri Mar 23, 2007 4:47 pm    Post subject: Reply with quote
darn it!!!
I have a nokia 6230i, how could i find out its bluetooth limitations??
robodan
PostPosted: Fri Mar 23, 2007 4:48 pm    Post subject: Reply with quote
Also Darren, have you had to change the passkey on your usb device in order for them to work? i.e will two devices using 0000 work on the same phone? should it support it obviously.
PostPosted: Fri Mar 23, 2007 5:12 pm    Post subject: Reply with quote
From what I can glean the 6230 does support multiple BT devices. There shouldn't be an issue with devices using the same passcode as you can only connect to one device of each type anyway i.e. One BT GPS (this uses SPP - Serial Port Profile) and one headset (headset profile).
It matters not if devices that use different profiles have the same passcodes. It's not possible to change the passcodes of many devices anyway.
robodan
PostPosted: Fri Mar 23, 2007 5:44 pm    Post subject: Reply with quote
they just wont work together at all, if i have my headset connected my tomtom will not update traffic etc, and if my tomtom is connected i just cannot connect my headset!!!
Sad
STWMATT
PostPosted: Sat Mar 24, 2007 5:38 pm    Post subject: Reply with quote
Hi, im using Nokia N73 connected to BT GPS unit, switch on bluetooth incar handsfree unit and hey presto tt directions over my handsfree unit, and incoming calls override tt so all is good and legal.
apogee
PostPosted: Sat May 05, 2007 5:59 pm    Post subject: Any more info on this?? Reply with quote
I have a sony k800i and a nokia bluetooth car kit in my car.
It would be fantastic to setup so i can dial calls via my tomtom and use traffic but have the speech and microphone, answer key etc on the car kit.
Anyone come across any more info on this?
Lee
PostPosted: Sat May 05, 2007 8:36 pm    Post subject: Reply with quote
robodan wrote:
darn it!!!
I have Nokia 6230i. It will PAIR with any number of devices (mine is paired with TTGO700, Jabra headset and MacBook laptop computer - I originally had it paired with three Jabra headsets - with different names - so as to swap them over when they ran out of charge), but will only connect with one at a time. I dunno if TT ONE does handsfree? I use my GO700 for handsfree, so it will also (if I want to, but I don't) pick up traffic via gprs on the phone. If the ONE doesn't do handsfree, you're stuck with only one or the other from the 6230i. Crying or Very sad
trevor.dowle
PostPosted: Sat May 05, 2007 8:40 pm    Post subject: Reply with quote
DennisN wrote:
robodan wrote:
darn it!!!
It doesn't.
Regards
Trev Dowle
TomTom 730 T
PostPosted: Sat May 05, 2007 10:12 pm    Post subject: Reply with quote
trevor.dowle wrote:
DennisN wrote:
robodan wrote:
darn it!!!
It doesn't.
Ahh - Quel domage and tough merde on robodan!
