Pocket GPS World :: View topic - Where is the distance-to-poi warning held?
AshleyHinton
PostPosted: Fri Mar 23, 2007 3:50 pm    Post subject: Where is the distance-to-poi warning held? Reply with quote
Forgive me if this is an FAQ (have done some searching..) but I've just installed the complete speed zoned + Liz voices warnings on my original GO.
Having used the consolodated by type for a few years (ie: Gatso, Mobile, etc) I decided to give the speed zoned ones a try.
I wonder if there was an easier way to set the warn-when-near prefs (ie: single file somewhere) than sit through typing "480 yds" etc into each and every POI on the TomTom?
Thanks,
Ashley
TT GO Original / v7 / 1GB SD - Mac's with 10.6 Snow Leopard - iPhone 3G with CoPilot, Navigon & NDrive - Linux PC with Crunchbang.
PostPosted: Fri Mar 23, 2007 4:00 pm    Post subject: Reply with quote
No easy short cut to this one - but once set-up you don't need to do it again, a database update replaces the POI files, but the warnings stay the same, think yourself lucky you don't have a 910 using the Text To Speech - setting that up takes ages Laughing - Mike
AshleyHinton
PostPosted: Fri Mar 23, 2007 4:05 pm    Post subject: Reply with quote
Thanks for that info Mike Smile
Indeed I found that once I'd set those prefs for my old cameras I just replaced the files each month without having to set them again - which will be the same if I choose to stick with the speed zoned version.
Have backed up both "versions" of my GO - just in case Smile
Cheers,
Ashley
22.055 (29 May 24)
