Pocket GPS World :: View topic - Muskokatech release PathAway GPS 4 - Professional Edition
PostPosted: Wed Feb 28, 2007 3:17 am    Post subject: Muskokatech release PathAway GPS 4 - Professional Edition Reply with quote
PathAway GPS Professional for Windows Mobile has been released. We will be doing a review of that software in the coming months, in the meantime please have a look at the newest feature list. Buddy communication seems to be the new vogue in GPS. (Really? What's your opinion?)
Details of PathAway GPS can be found at http://pathaway.com/pw4prodetails.htm .
If you want to try it out - the direct download location is at http://pathaway.com/dlpw4prowm/
PathAway Professional Edition has all of the features of PathAway GPS 4 - Standard Edition plus new features targeted towards power users and professionals. Of significance, PathAway PRO has 2-way wireless remote location tracking. See where others are right from your handheld, share your location with others, or send to a central tracking service.
Send My Location: (SMS capability or Internet connection required)
Send current GPS location to another user or remote tracking service via SMS or Http protocol. See PathAway Send/Receive Format document for the supported send formats. Send manually via command, or have location sent automatically based on the following frequency intervals:
Automatic Time Interval: Send location at the specified time intervals.
Automatic Distance Interval. Send is triggered every x distance traveled.
Automatic Distance Interval from Start. Sends your location as you cross the threshold of the specified distance from your start location. If you move back towards your start location, the trigger will again send the location. This feature is very useful for search and rescue purposes where the distance from a start location is needed in order to determine a search radius.
Retrieve Remote Locations (SMS capability or Internet connection required)
As new Remotes are retrieved, they are assigned a default background color for display on the map. This color can be modified by Editing the Remote Item Info. Remotes are tracked by their ID passed along with the location message. The Label for a remote can be modified by the user for easier on-screen identification.
Retrieval is achieved either when an SMS message containing location information is received, or via automatic or manual polling of an Http-based Tracking server.
For Servers that return timestamp information, PathAway will download only updated location information.
On-Map Remote Labels:
- For each remote location being tracked, the tag on the map can display current location and heading of remotes, course, speed, elevation of remote, date/time of retrieval, distance to, course to, and elevation difference.
Remotes View Screen.
Shows the map and list of Remotes. Remotes are listed showing distance and heading to. Tap and hold on an item to bring up the context menu for commands to issue on the remote item.
Remotes Commands
- Enable Remote Tracking. This will toggle the automatic send/retrieve of locations
- Goto Next Remote, Goto Previous Remote. Centers map on Remote.
- Concept of Active Remote. Active Remote is the current (or last) remote the screen was centered on. Goto Active Remote centers map on this remote.
- Auto Center Remote. This will cycle through all of the enabled remotes.
Calculate Location by Vector
Calculate a new Location by entering a distance and course from a starting location.
Available from Goto Location and Point Edit Location dialogs. Great for geocaching when you're provided only with a course and distance vector from your current location.
Directional Alarms
- In addition to the off-track and altitude warnings, turn instructions, and proximity notifications, PRO now offers different alarm sounds for left and right turns, left and right of off-track warning, and high and low elevation warnings.
Custom Alarms can trigger external programs
- Set the alarm sound in a Point to "EXEC <url or program name>" to have PathAway launch a special program or call up a Web Page when the proximity to the point has been reached. Great for tour guide application.
Map Display
- Views of Distance Radials on Map. See View->Map Display... settings. Displays distance radials in predefined distance rings.
Find Location by Street Address Lookup: (Internet connectivity required)
Enter a street address, then choose from the closest points found. Choose whether to show the point on the map, add a new point, or navigate to the address location.
New Find Location Dialog
- New Find Location dialog is now a Wizard style to provide step-by-step assistance on finding the location you're looking for. Options include: select location by coordinates, Online Street Address lookup, Point database lookup, or start of track or route locate. Once found, choose whether to show the point on the map, add a new point, or navigate to the new point.
New Preferences
- New preferences option "Backlight on while connected" allows you to force the backlight on or use the system backlight settings.
- Automatically set time to GPS time. When the time on the handheld is out by more than 1 minute compared to the time received from the GPS, PathAway will automatically adjust the time on the handheld.
User Interface Improvements
- Added New UI Elements including Reorganized Menus. Optional Text-based tools option for one handed control. (See View->Text Menus). Switch directional arrows between Zoom map, Scroll map, select item on map, and select dashboard item.
- GPS Status added as a Dashboard option.
- "Show Note" to Point Context Menu. Displays note text of waypoint. Also, a 'T' icon will show on the Proximity Dash item. Click on the 'T' to show the waypoint Notes.
- Screens made square and widescreen aware.
- UI Screens now utilize Windows Mobile 5 command key buttons.
GPS Communications
New GPS Communications Protocol "Windows Mobile GPS" (Windows Mobile 5.0 only):
This protocol uses the Windows Mobile Intermediate GPS Driver to obtain GPS Information. This is now the default and recommended protocol for WM5 handhelds. Using this protocol, GPS connections can be shared with other applications. Note, the Start->GPS Settings->Access" "manage GPS automatically setting must be turned on for this protocol to work. This problem also resolves a crash using NMEA + COM when the device is turned off while the GPS is connected. Note, with this setting, the port, baud and other communications settings are not used.
PathAway Map Manager
- Basic support added for OZIExplorer .map and .geo import. Currently supports multi-point calibration in "dd mm.mmm" format. Open the map by bitmap name (ie. map.jpg) and PathAway will look for an associated Map or .geo calibration file.
- Map Manager, support for PNG, GIF and TIF files.
Experimental Features:
PathAway PRO also includes some features that are not considered to be part of the commercial package, but are included for experimental and special interest purposes. They are included to encourage feedback from you, and to highlight some of the R&D that is being done at the PathAway Lab. Experimental features may or may not appear in future product releases. The following features are currently available for experimental purposes only.
Web Maps (Internet connection required)
Designed for Phone Edition Pocket PCs, Web Maps allows you to download maps on-the-fly from a Map Server. Maps will be downloaded in the background and displayed on the screen as they complete downloading. Maps are cached, so downloading only needs to be done once. See Options->Web Maps Dialog to configure.
Note: WebMaps is considered to be an experimental feature provided at no extra charge. WebMaps downloads data from third-party Map Servers so availability of these maps may change at any time without notice. MuskokaTech provides no warranty or support of the quality of these maps.
Maps currently supported:
Google Maps: Worldwide street and satellite maps.
Terraserver-USA Maps: USGA Topographic and aeriel photo maps. Covers USA only.
philpugh
PostPosted: Wed Feb 28, 2007 6:13 pm    Post subject: Reply with quote
Buddy communication --- is this something that marketing are telling us we all want Laughing Don't see the point myself - if I want anyone to know where I am - I'll give them a call.
If you are a business wanting to track your workforce then this isn't the solution as you can turn it off all too easily. Ok - I'll concede that you could load it onto embedded WM2003/WM5 capable hardware and then it's yet another tracking device - but hat is hardly a buddy comms device. As to its use for search-and-rescue I would hazard a guess that if you need to be looked for and recovered then you may be in a location that possibly doesn't have good 'phone / internet connectivity unless you are using satellite comms. I don't include breaking down by the side of the road in this category - you would probably just 'phone someone up in this case.
Phil
22.055 (29 May 24)
