Pocket GPS World :: View topic - Go 910 Specs & Redlight cams not in POI list??
rol1968
PostPosted: Tue Feb 27, 2007 10:19 am    Post subject: Go 910 Specs & Redlight cams not in POI list?? Reply with quote
As the topic suggests, when I go to add a warning for the specs and redlight cameras, they are not in the POI list. The info and the bitmaps are on the device as I have browsed the Tom Tom's drive to find them.
The Gatso's and mobiles are in there, no problem but I just can't find the others.
Could anybody help please??
Many thanks in advance
Geoff
PostPosted: Tue Feb 27, 2007 10:53 am    Post subject: Reply with quote
How many other custom POIs do you have installed?
rol1968
PostPosted: Tue Feb 27, 2007 11:10 am    Post subject: Reply with quote
None other than the Pocketgps ones I dowloaded.
I have just checked, 24 in total.
Thanks for replying by the way Smile
PostPosted: Tue Feb 27, 2007 11:55 am    Post subject: Reply with quote
And are they all enabled in the POI Configuration section?
rol1968
PostPosted: Tue Feb 27, 2007 12:24 pm    Post subject: Reply with quote
They didn't even appear in that list. I have deleted a few of the 20 mph gatsos and now he specs cameras appear.
PostPosted: Tue Feb 27, 2007 12:36 pm    Post subject: Reply with quote
That suggests that you have other POIs either installed or partially installed.
The simplest solution is to remove all the POIs in the map folder and start afresh. You can safely delete all the files that end in .ov2 or .bmp and then reinstall.
Usual caveats apply, if you are not comfortable with doing this then don't and ensure you have a current backup before you do!
rol1968
PostPosted: Tue Feb 27, 2007 12:37 pm    Post subject: Reply with quote
Thanks very much Darren for your help.
Geoff
