Pocket GPS World :: View topic - Wiring a GPSLIM 236 unit to a switch power supply in the car
mrralphman
PostPosted: Tue Feb 27, 2007 4:00 am    Post subject: Wiring a GPSLIM 236 unit to a switch power supply in the car Reply with quote
Hi all,
I am thinking of buying the 236 Blue Tooth GPS receiver and would love to be able to peminantly connect it to a switched power supply. This way I could leave it in the car and not worry about it running out of juice.
It's the adaptor that I need info on.
Thanks all,
Paul.
Adamwest
PostPosted: Sat Mar 03, 2007 5:32 pm    Post subject: Reply with quote
adapter for what?
you get a charger with it. I took the battery out, left it switched on and wired it up to a switched live so that it comes on with the ignition
Skippy
PostPosted: Sat Mar 03, 2007 8:30 pm    Post subject: Reply with quote
You could use a cigarette to USB "A" adaptor with a USB "A" to "B" cable which you can get from most electronics shops.
Bear in mind that you may have troubles with a long time to first fix if the GPS unit loses it's almanac data. Certainly my Holux does if I remove the battery or run it completely flat...
Gone fishing!
Adamwest
PostPosted: Tue Mar 13, 2007 7:36 am    Post subject: Reply with quote
you get that with the unit
