tonygold Frequent Visitor
Posted: Wed Feb 14, 2007 1:32 pm Post subject: latest camera database |
need some help please. just downloaded most recent 14th feb release (24 file version) and understand some extra files have been added, but i seem to have 33 ov2 files now. is this right??
also
i still seem to only get boings at certain mobile sites and specs areas. all other cameras work with appropriate ogg voice files just fine. any ideas?? i seem to have appropriate ogg files for all the camera files??
thanks
tony. |
Posted: Wed Feb 14, 2007 1:35 pm Post subject: |
right, just seen the details of latest download and 33 files is correct - so that sorted.
but....
any ideas about my 2nd point re: boings on specs and mobile sites instead of worded ogg warnings.
thanks. |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15151 Location: Bradford, West Yorkshire
Posted: Wed Feb 14, 2007 1:52 pm Post subject: |
the 'some mobile sites' will be the pmobile ov2 files (unverified - 'p' for pending) as you will need a new ogg file to match the name.
re the specs, you need to make sure you have an ogg file with the same name as the specs ov2 and bmp files
MaFt |
Posted: Wed Feb 14, 2007 2:26 pm Post subject: |
thats the strange thing. i do seem to have correctly named ogg files for the mobiles and specs but still i omly get boings etc.
not a major issue but just baffling me!!! |
rugrat2 Regular Visitor
Joined: Aug 14, 2005 Posts: 170 Location: Hull East Yorks
Posted: Wed Feb 14, 2007 6:05 pm Post subject: |
tonygold wrote: | thats the strange thing. i do seem to have correctly named ogg files for the mobiles and specs but still i omly get boings etc.
Dont forget to delete the warnings for those cameras, and then reinstall the warning, and it should then pick up on the ogg file.. _________________ Neil.......ttgo..Mio p550...2.8 lwb exeed pajero. where cant I go.. |
Posted: Wed Feb 14, 2007 6:28 pm Post subject: |
in my map folder i only seem to have the ogg file, unless you mean delete warning from the actual tomtom unit menu???
how do i do this please?? |
Oldboy Pocket GPS Moderator
Posted: Wed Feb 14, 2007 8:01 pm Post subject: |
Go through the Warn When Near routine again, for those Cameras that are giving the wrong warning.
If you are still asked to select a warning it means there is something wrong with the naming of that ogg File _________________ Richard
Posted: Wed Feb 14, 2007 8:52 pm Post subject: |
hi oldboy,
when i go into 'manage poi' menu, i select the specs camera,
next screen asks ' delete poi' - i answer no
then i set the yardage warning
then i set warn only if poi is on route
and thats it. it does not ask for a warning sound to be set?? |
Posted: Thu Feb 15, 2007 8:14 am Post subject: |
Then it has picked up the ogg File.
Just remember that if you Tick for Only Warn When on Route, you won't get any warning at all while using it without Routing Instructions. _________________ Richard
pete1336 Lifetime Member
Joined: Jul 22, 2006 Posts: 274 Location: North Wales
Posted: Thu Feb 15, 2007 10:27 am Post subject: New ogg file? |
For those of us without the correct ogg file for the new pending cams (me) where can I obtain one from?
For the rest of my speed cams I'm using the Liz voice, I'd prefer to use a new Liz ogg file if possible for the pending cams but if there isn't one of Liz I suppose any other human voice will do.
Thanks in advance.
Pete |
Posted: Thu Feb 15, 2007 10:49 am Post subject: |
Sorry I should have clarified, mine are the Liz Whittaker voice promps |
JockTamsonsBairn Lifetime Member
Joined: Jan 10, 2004 Posts: 2777 Location: Bonnie Scotland (West Central)
Posted: Thu Feb 15, 2007 12:00 pm Post subject: Re: New ogg file? |
pete1336 wrote: | For those of us without the correct ogg file for the new pending cams (me) where can I obtain one from?
Thanks in advance.
Pete | Copy the existing ones. e.g. copy Mobile30.ogg to pMobile30.ogg _________________ Jock
TomTom Go 940 LIVE (9.510, Europe v915.5074 on SD & 8.371, WCE v875.3613 on board) |
Posted: Thu Feb 15, 2007 1:55 pm Post subject: |
Thank you BGF, much appreciated :D |
Mullet Frequent Visitor
Posted: Fri Feb 16, 2007 2:28 am Post subject: |
deleted
Posted: Fri Feb 16, 2007 12:25 pm Post subject: |
Mullet wrote: | Pete. I have decided to use the single file from the consolidated set as I don't want to use an extra five POIs on my TTNv5.21
I modified an existing .ogg file based on Ray Flanagans Liz Whitaker files simply stating "warning unverified mobile camera ahead" to cover the whole category.
They are louder than the originals so you would need to install the full set.
Too tired to host and cross check right now so PM me your email if you want them. |
Done, thank you :D |
