Pocket GPS World :: View topic - What version TomTom
What version TomTom
private4587
PostPosted: Mon Feb 05, 2007 6:57 pm    Post subject: What version TomTom Reply with quote
Could any one tell the latest version of TomTom Navigator that will work with my Plam Tungsten T3, I have a stand alone GPS.
Howarduk
PostPosted: Mon Feb 05, 2007 11:49 pm    Post subject: Reply with quote
Hi Private4587
If you check the TomTom website you will find that they do not reccommend TT6 for your Palm. However, that's not to say it won't work. I'm sure others on here will be able to say if your Palm will work okay with TT6. Which leaves you with TT5. Which I think should work.
Howard
Ipaq 214 WM 6.0
TT6.030
CF-BC337 GPS
Active Synch 4.5
MohairSofa Calendar+Today Plug-in Ver.2.5.2
Softwinter Storage Tools Ver.2.0 ppc 420
Pocket Informant 9.01 build2390
Sprite Back up Ver 6.5.4 build 16
DougUK
PostPosted: Fri Feb 09, 2007 5:22 pm    Post subject: TTN6 on a Palm Tunsgten T3 Reply with quote
I have TTN6 running fine on my Palm T3.
TomTom Home doesn't recognise the Palm per se, but will install fine to the SD Card via a card reader. I've noticed no problems with performance either. Route generation is fast (light years ahead of MapSonic which I had before) and there is no perceptable lag when on the move.
private4587
PostPosted: Wed Feb 14, 2007 10:36 am    Post subject: TT6 on Palm T3 Reply with quote
I have tried to install to my SD card but when attempting to run I keep getting fatal errors. Any idea what I am doing wrong. Should I just stay with version 5 or are improvements that much worhwhile.
DougUK
PostPosted: Wed Feb 14, 2007 10:52 am    Post subject: Reply with quote
I assume you have AppSlipRotate and StatusBarLib installed (the fix to allow the full screen to be used).
Before downgrading, you might want to try backing up your Palm, then installing only TTN6 (and the above two PRCs) and see if you still get fatal errors. If you don't then start adding one app at a time - could be some sort of conflict.
If you still get fatal errors with a clean Palm, then it might be your SD card. If you have the opportunity to try another one, then this might help you eliminate the cause.
Like I said, I have TTN6 working fine on my Palm T3 and it's one of the few apps where I haven't had a fatal exception.
Ah - one more thing to try (possibly the first thing if you are using a bluetooth GPS) - I remember when I used MapSonic I would get regular fatal exceptions when connecting to a bluetooth GPS. A workaround was to delete the bluetooth pairing, and then it would work (the next time only). A permanent solution is to delete the bluetooth cache, which apparently had become corrupt. I can't remember it's exact name as I have conveniently mislaid my T3 today.
Good luck!
Doug
7272Andy
PostPosted: Wed Feb 14, 2007 10:53 am    Post subject: Reply with quote
To my mind I'm not totally convinced that the "improvements" are worth the upgrade, although having the more up-to date map is.
Just to let you know I'm running TT v6.010 and UK & ROI map v660. I have had no problems with it so far (although the scrolling when on the move, with all POIs disabled, is not as smooth as TT v5 was).
I'm willing to give you a hand getting set-up if I can.
Oh, and Welcome to the forums by the way Thumbs Up
Samsung Note 20 ultra
CamerAlert
Waze
private4587
PostPosted: Fri Feb 23, 2007 10:21 am    Post subject: TT6 On Palm T3 Reply with quote
Thanks for all your assistance but have decided to stickwith my version but have got the latest maps working with this so again many thanks.
Nobber
PostPosted: Sat Feb 24, 2007 11:00 am    Post subject: Reply with quote
I've got a C600 and am trying to install tt6, it won't let me install to the device as there is not enough memory but when I choose install to storage card it sstats then fails at about 50%
any ideas
thanks
Nobber
Nobber
PostPosted: Mon Feb 26, 2007 11:10 pm    Post subject: Reply with quote
hi any help please ie will navigator 6 run on my c600 or 6.01 6.???
thanks
